Old 12-30-2008, 09:32 PM   #1
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
Thumbs up The $53.50 eBay HID Kit Installed & Working
So I made myself a guinea pig, plus my buddy had a $70 set from ebay with great results so I went for it.
The kit is a 35W H1 8000K
Heres the pictures and a video as well.
The video was taken with a point n shoot camera so dont be too hasty to call the light output bad because its actually very good.
Half & Half
SAME AS ABOVE EXCEPT SPED UP TO SHOW WARM-UP PERIOD
PG TLD22 8V Line Driver
Old 12-30-2008, 09:34 PM   #2
i wouldnt go w/ 8000k personally...poorer visibility than other colours...
did you end up losing your high beams?
Old 12-30-2008, 09:36 PM   #3
The Architect
Give Me Resonance
that i did, i thought i ordered the 6000k but i guess i forgot. either way theyre drastically brighter than the 6000k bulbs i had in before, im very happy.
Old 12-30-2008, 09:55 PM   #4
jinxor
jinxor's Avatar
Drives: Yaris 3dr YRS
is that a 35W kit or a 55W kit?
Old 12-30-2008, 09:57 PM   #5
The Architect
Give Me Resonance
35w
55w jumps up to i think $159 on ebay, idk about anywhere else.
Old 12-30-2008, 10:07 PM   #6
jinxor
jinxor's Avatar
can you post a link to the hid page mate... thanks
Old 12-30-2008, 10:08 PM   #7
Looks a tad bit high. Can you aim them down a bit?
Unless the driveway is inclined.
Old 12-30-2008, 10:09 PM   #8
The Architect
Give Me Resonance
http://cgi.ebay.com/ebaymotors/XENON...Q5fAccessories
thats what ive thought since the day i got the projectors.
im sure i can, ive heard you have to adjust the screws inside the headlight near where the bulbs go in.
anyone wanna fill me in?
Old 12-30-2008, 10:15 PM   #9
hmmmm...
Old 12-30-2008, 10:16 PM   #10
The Architect
Give Me Resonance
the difference is drastic, i dont even need my fogs anymore. id recommend them to everyone so far.
Ill give an update should anything change in stability/functionality etc.
Old 12-30-2008, 10:18 PM   #11
Yeah, my HID's are a huge upgrade from the stocks, the Luminics, and the Sylvannia's I had prior to it. Although, since I don't have projectors, it's a bit glar-ie, so I had to aim them waaaay down.
Old 12-30-2008, 10:58 PM   #12
GreenSpeed
Drives: '08 Yaris LB
I just picked up a set of the depo lights like yours. I'm sure there's a thread about it somewhere, but was the install simply mounting the ballast, connecting wires and replacing the stock bulb with the Xenon bulb?
Well done on the videos and pics!
GreenSpeed is offline   Reply With Quote
Old 12-30-2008, 11:12 PM   #13
The Architect
Give Me Resonance
keep in mind i no longer have my high beams, then again it should also be noted that the projectors reach pretty high up while also not blinding any oncoming traffic.
the install was very straight forward, swab the bulbs, plug in the power and ground to the stock harness...and your golden.
Old 12-30-2008, 11:19 PM   #14
Yaris Palme
MAZDASPEED3
Yaris Palme's Avatar
Drives: MazdaSpeed3
Send a message via ICQ to Yaris Palme
i don´t like this HID Kits..... This kits are flashing the other drivers in front of you so much...... for the other driver it looks like he is looking direct into the sunlinght.
Yaris Palme is offline   Reply With Quote
Old 12-31-2008, 12:11 AM   #15
The Architect
Give Me Resonance
not with the projectors, the cutoff is great and ive never been high beamed/flashed/etc. for any stray light.
Old 01-02-2009, 09:32 PM   #16
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
That's insanely bright! I would personally drop it down to 5000K to get a more optimal white projection without the excessive brightness. That's just me though
On the bright side (no pun intended), maybe now we won't find anymore threads about LBs hitting deers
Old 12-31-2008, 12:37 AM   #17
To prove non-believers wrong, I've seen people take pics of their lights behind another car (parked) to show where the cutoff is at.
Old 12-31-2008, 06:55 PM   #18
89GLH
Drives: 2009 Yaris 4 door hatch
theres the reason aftermarket HID kits are illegal in some states. For $1 I bet the stock lights light better.
89GLH is offline   Reply With Quote
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 02:05 PM
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 01:56 PM
Mcculloch HID BIXENON from ebay 409$ yv1650c General Yaris / Vitz Discussion 23 04-25-2007 01:55 AM
