Old 01-01-2009, 06:20 PM   #1
bye bye water pump
Ready to upgrade to an electric water pump. This will be controlled by the AEM EMS. That means it can be run even after the car is shut off (and other neat options).
Without this and the A/C, the car will be running only two pulleys.
Picture is on the built motor. (Don't worry, the NST crank pulley will be transferred over )
Old 01-01-2009, 06:23 PM   #2
sweet!
next step, electric alternator?
Old 01-01-2009, 06:28 PM   #3
ChinoCharles
Drives: LB
Niiiice.
Old 01-01-2009, 08:29 PM   #4
richardholdener
Drives: 2008 Yaris hatch
This photo shows the block off plate but where is the (I'm assuming) remote pump?
richardholdener is offline   Reply With Quote
Old 01-01-2009, 08:31 PM   #5
richardholdener
Cali-we ran an electric water pump (from a Civic) on the Yaris. We stuck it inline in the lower radiator hose and simply disconnected the water pump pulley for dyno testing. Getting rid of accessory drive from water pump is worth a few extra horsepoweer.
Old 01-01-2009, 08:42 PM   #6
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Electric water pumps seem unreliable to me. It's not the pump itself but more the thermostat to engage it that scares me. It's obviously a simple way to gain a few hp though.
Old 01-01-2009, 09:13 PM   #7
The remote pump isn't installed yet, since the motor is sitting on a stand waiting our swap. Hadn't thought of using a Civic pump, I was going to buy a new aftermarket one. Thanks for yet another good idea, Richard!
Electric pump setups are very reliable (e.g., Civics have them) - this one will be controlled by the AEM as my first post mentioned. Mechanical pumps fail, too - as do thermostats. Just have to watch the temp, another good reason to have real gauges on these project cars!
Old 01-01-2009, 09:25 PM   #8
NonStopTuning
Looking good so far Garm. Where did you get the block off plate?
MIKE @ NST
www.NonStopTuning.com
Old 01-01-2009, 09:35 PM   #9
Art had it made, or made it himself -- he sent me the pic from his cell yesterday.
I wouldn't mind a spacer for the oil pan, for a little more capacity.....hint hint... NST...hint hint....
Old 01-02-2009, 12:39 AM   #10
NonStopTuning
Let's do it!!! You know how to find me to get the ball rolling
MIKE @ NST
Old 01-01-2009, 09:59 PM   #11
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
I love it Garm , go bigg or go home . Damn your car is gonna be a freakin' track(drag/road) monster after the engine swap/Aem ems is done/tuned, Omfg !
Old 01-02-2009, 04:44 AM   #12
ddongbap
Electric water pump. Now thats what I'm talkinga bout.
Old 01-02-2009, 03:29 PM   #13
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Nice work!
Old 01-02-2009, 03:38 PM   #14
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i know more oil capacity for a stock internal n/a car may not be necessary, but if the price is right..ill support nst and micro image! ;)
Old 01-02-2009, 03:47 PM   #15
largeorangefont
Break'em off some.
For open tracking the car is probably needs something extra. I have not seen the oil pan and windage tray, but I doubt it was designed with sustained high g turns in mind.
Garm, to be honest you should probably just do an Accusump setup to protect yourself from oil starvation. It is only a couple hundred bucks.
Old 01-02-2009, 03:52 PM   #16
mikenacarato
SIPNDEW
Drives: 15 STI
i do plan on autocrossing this car as well as taking it on a few road courses. maybe a pan to hold an extra quart would be sufficient? would cooling fins on the pan work to keep the temps down as well?
Old 01-02-2009, 04:00 PM   #17
largeorangefont
Break'em off some.
Adding some extra oil could be a good idea. Really you need someone with their oil pan off to see how much extra you can actually put in. Someone like Garm who has their engine out already :)
It is kind of a mystery as to how much to add. As a guess I would say 1 quart would be too much. That is over 25% of the total capacity.
I have no data to make a concrete statement though.
Again, I'm not sure on how hot the oil runs in this car. I don't have a gauge in mine. I'm sure a finned pan would help a bit.
Old 01-02-2009, 04:03 PM   #18
mikenacarato
SIPNDEW
Drives: 15 STI
well i believe we need to conduct some studies. to get the temp would a filter sandwich adapter and gauge be accurate enough to read temps?
electric water pump help! mandriu Performance Modifications 39 10-24-2009 02:56 AM
Bye Bye Yaris, hello...... id3379 General Yaris / Vitz Discussion 39 12-07-2008 02:36 PM
Water temperature Bob_VT General Yaris / Vitz Discussion 11 11-03-2008 03:17 PM
Good Bye Thomas Thread uncleyaris General Yaris / Vitz Discussion 27 07-05-2007 08:38 PM
