![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
Throttle ?
Is it better to drive in a higher gear with more throttle or lower gear with less throttle? Maybe 500-600 RPM difference. And this doesnt have to apply to just the Yaris.
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
Depends on if you're going uphill or down, but if you're on a flat road you want to be in the highest gear at the lowest rpm which allows you to not put too high a load on the engine if you want the best possible efficiency.
Going uphill you need higher rpms, going down a hill you need less. You have to go by feel. You'll know when you don't have enough rpms for what you're trying to do because the car will sound different and be unresponsive. |
| 1zzfe throttle body | lilman717 | Performance Modifications | 22 | 02-12-2009 07:08 PM |
| FS: 1zzfe throttle body | thebarber | Items for Sale by private party | 5 | 01-04-2009 04:06 AM |
| Throttle position used as cruise control? HELP | Appalachian Trail 2007 | Performance Modifications | 11 | 11-09-2008 11:10 PM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
| toyotafest 2007 | esquiva | Photo-Video-Media Gallery | 36 | 05-15-2007 12:03 PM |
