Adding DRL
What would I need in order to get DRLs working on my Yari? I have tried the parking lights thing but it dims my dash way too much. Any suggestions? Can I just buy the relay module and is it an easy install? Or is there complex wiring involved?
Thanks! |
![]() ![]() ![]() Drives: 08 toyota yaris LB Join Date: Oct 2008
I think its just plug and play with the relay.
So where can I obtain this relay? Is anyone who removed the DRLs willing to give it to me? I'll pay shipping, or if someone is in the Orlando area that would be great.
Thanks! |
can't you adjust how your display looks when your parking lights are on? i can turn mine on to look as bright as they do when my lights arent on....
I have the little dial all the way up and since I do live in the Sunshine State
the illumination is just not enough like I have to force my eyes to see it clearly.
doesnt it click past that though...? mine does....
Hmm will check BRB
You are a genius!!!!
Thanks yeah never would have thought to click it further. Ok that is a problem solved. So The DRLs would be parking or normal beams? |
#9 | |
drl's come on as low beams, but they dont run at full intensity....so theyre dimmer why do you want drl's so bad anyways?
Yeah much easier.
As for reason, my godfather wanted me to have them for safety I guess? Thanks again! |
#11 | |
as long as you turn on your headlights when its foggy/rainy/snowy or at dusk/dawn, youll be ok drl's dont give you tail lights either just need common sense, not drls (btw, that common sense thing isnt a dig on you....but lots of ppl out here think they have drl's so theyre ok....but i cant tell you how many time people SHOULD have their lights on in the fog and dark out here and dont because they can see because of the drl's being on...its sick /rant)
Well I am extra safe then cause I don't have real DRLs. Instead I'll have my low beams on and will build a habit to always turn them on. :)
#13 | |
http://www.webelectricproducts.com/ I put them on my Yaris and like the look. I believe I have a pic in my garage section with them activated.
2007 Silver Streak Mica Yaris S Sedan 5 Speed dojo TSUKAMI Shift Nob Brake Light Pulser Daytime Running Lights http://www.webelectricproducts.com/products.htm |
#14 |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
i have 2 drl relay boxes.. o took them out of my 07 and my 08
"It hurts more when its wet" |
#15 |
Problem already solved thanks everyone!
#16 |
![]() Drives: 2007 Yaris 1.0 Sol Join Date: Oct 2008
How did you do it?
#17 |
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
LoL a CLICK past the DIMMER!
R-CaT Project Yar 2ZR |
| DRL Questions. | AznGouki | Cosmetic Modifications (Exterior/Interior) | 14 | 10-28-2008 03:07 PM |
| DRL disalbled. | IllusionX | DIY / Maintenance / Service | 0 | 10-22-2008 03:16 PM |
| Using parking light as DRL? | GabL | DIY / Maintenance / Service | 6 | 11-11-2006 09:31 AM |
| adding DRL's..?? | static808 | DIY / Maintenance / Service | 9 | 10-20-2006 04:15 AM |
| NO DRL ???? | argylesocks | DIY / Maintenance / Service | 8 | 08-12-2006 08:24 PM |
