Old 01-06-2009, 12:41 PM   #1
coheed
Drives: 08 BB LB
Maxxim Weight
Does anyone know the wheight on the maxxim screech's or the rota flashback's? I know that most people dont like "knock off" wheels but Id rather spend more money on tires than wheels.
Old 01-06-2009, 02:27 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
what size width and offset
Old 01-06-2009, 04:28 PM   #3
coheed
Drives: 08 BB LB
Rota's 15x7 +40
Maxxim's 16x7 +38 13.6 lbs
And found another sat the same style, but still can't find the weight.
Drag DR20's 16x7 +40 12.7 lbs
Really looking at the Maxxims but don't know if they will rub because of the offset being lowwer. If that might be a problem I'll go with The Drags.
Old 01-06-2009, 04:33 PM   #4
Originally Posted by coheed View Post
Rota's 15x7 +40
Maxxim's 16x7 +38
will 2mm of offset difference be the deciding factor on whether they rub or not?
Old 01-06-2009, 04:39 PM   #5
coheed
Drives: 08 BB LB
Not sure thats why I brought it up. I dont honestly know. I'm thinking it all depends on tire choice. But I'm still not gettin the info I wanted. I would like to know how much the weigh each. I'm pretty sure their close but still. Any help would be appreciated. And I have look and searched.
Old 01-06-2009, 04:32 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
Maxxim, 16x7, ET38, OEM size 195/50/16 should be fine.
Old 01-06-2009, 05:13 PM   #7
kimona
kimona's Avatar
Don't have the weight for you, but yes 2mm makes a significant difference on our cars.
Old 01-06-2009, 06:24 PM   #8
coheed
Drives: 08 BB LB
So would +40 or +38 be better? edited the third post.
Old 01-06-2009, 09:02 PM   #9
kimona
kimona's Avatar
Ideally, ET42 or greater works best up front. With 15/16's, if you opt for ET38-40, then run 195mm rubber. With ET42 plus, you can run 205mm rubber.
Old 01-06-2009, 09:56 PM   #10
coheed
Drives: 08 BB LB
Alright. So I'll go with the Drag's cause thier lighter and have the higher ET.
Old 01-06-2009, 10:25 PM   #11
kimona
kimona's Avatar
Here's something very similar on johnnypaseo's Vitz: If I reacll, they're Maxxim 16x7, ET38, with 195/50/16 tyres.
Old 01-07-2009, 12:00 AM   #12
coheed
Drives: 08 BB LB
Was he lowered? I plan on gettin Tein's.
Old 01-07-2009, 12:50 AM   #13
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
Drives: 2007 toyota yaris
i run et38, 205-45 on tein coilovers, no rub
Old 01-07-2009, 01:04 AM   #14
coheed
Drives: 08 BB LB
Nice, how low do you have it?
Old 01-07-2009, 01:05 AM   #15
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
about 2 inches
Old 01-07-2009, 01:06 AM   #16
coheed
Drives: 08 BB LB
Do you think I'd rub with just the Tein springs. Bout the same height but softer, obviously. Cant really afford coilovers on a college budget.
Old 01-07-2009, 01:17 AM   #17
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
i think you'll be fine.. i could go lower if i wanted.. like another 3/4" or so.. u should be fine
Old 01-07-2009, 01:18 AM   #18
coheed
Drives: 08 BB LB
Sweet thanks.
Weight Savings 03Z33 Performance Modifications 30 01-31-2009 04:14 PM
6lb 6oz ultra light weight battery heavystarch Performance Modifications 28 11-19-2008 06:02 PM
Yaris Curb Weight, difference LB vs Sedan CASTREX General Yaris / Vitz Discussion 14 12-12-2006 09:50 AM
15" alloys weight? obylium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-25-2006 12:05 AM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
