Old 01-09-2009, 10:15 PM   #1
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
Do you feel ur Yaris shaking when waiting at red light?
just curious if you can feel the floor area where you place your feet(by pedals) - shaking when idling
Yawesh is offline   Reply With Quote
Old 01-09-2009, 10:28 PM   #2
YAR1S
YAR1S's Avatar
when the AC is on... and when the exhaust hums a bit..... happens rarely, but I notice it.... could be another car next to you? Sometimes I find myself tapping my foot and that much of a movement can shake the whole car, hhaaha.
-Jen <3
Old 01-09-2009, 10:31 PM   #3
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
nope tested on a empty quiet place, not on a bridge/highway either
it shakes alright
Old 01-09-2009, 11:47 PM   #4
ddongbap
it shakes alright
Maybe you're running 12030912930 lbs of torque.
Old 01-10-2009, 12:06 AM   #5
XYaris
Drives: '09 Yaris LB
shaking for sure
Having a tach installed helped me to immediately understand what the shaking is and that it is not a real issue.
When I idle at a light, in nuetral (5sp) but Im not pressing on the brakes the engine will be idling @ ~1000rpm. When I apply the brakes the rpms drop down to say 700 or so, causing a definite vibration. If I let up on brakes, the revs go slightly higher and the shaking goes away. The power brakes are parasitic to such a point on this engine that you can feel the engine adjust to running them. I could see this being a more continual feeling if you drive a automatic.
Anyway, this is the only vibration I have noticed in the car. Im not sure if thats what your referencing. The phenomenon I described seems totally normal and harmless to me.
XYaris is offline   Reply With Quote
Old 01-10-2009, 12:18 AM   #6
chibipod
Drives: '09 3DR LB S MT Meteorite
That's odd - when mine's warmed up it will idle at 600rpm rock solid (with or w/out brakes applied). Haven't used the A/C much yet, but I'll see if that changes things. 1000rpm seems a bit high.
Doesn't shake, either.
chibipod is offline   Reply With Quote
Old 01-10-2009, 02:00 AM   #7
mackie421
Drives: 2008 Yaris Liftback
Wow, I'll be installing my tach this weekend barring any weather related setbacks, and I'll definitely look for this once I get it working. I haven't noticed the engine to be revving any higher with the brakes on in neutral. I have noticed the engine rev a little higher for a few seconds randomly, regardless of whether or not the brakes are on.
mackie421 is offline   Reply With Quote
Old 12-06-2014, 12:32 AM   #8
Jcp123
Drives: '00 Echo
It's not the brakes themselves, your engine is pumping that vacuum either way. It's the brake lights. I can feel the same thing running wipers, headlights, rear defrost, etc. that energy has to come from somewhere...
Jcp123 is offline   Reply With Quote
Old 01-09-2009, 11:47 PM   #9
ddongbap
Dude, thats for sure.
Old 01-09-2009, 10:30 PM   #10
ZING
ZING's Avatar
Drives: Yaris '09,GTi '09, BMW 3.30ci
My yaris does a lot of funny things, there's this very weird sound I keep hearing..creaking sound...learned to ignore it hehe
EDIT: Answer to question; I don't feel it.
ZING is offline   Reply With Quote
Old 01-10-2009, 12:42 AM   #11
gid
yes , the '08 automatic does most of the time , worse on cold starts ( sits all night ) . This is without the A.C. that's used very little . Is a bit concerning . The '08 5 speed L.B. very seldom . Wonder if this is only for the automtics . Is yours an automatic that idles rough ?
Old 01-10-2009, 06:38 AM   #12
Forrest
Drives: 08 LB BLACK
Never noticed any unusual shaking on idle..yet.
Forrest is offline   Reply With Quote
Old 01-10-2009, 09:18 AM   #13
XYaris
to clarify. The engine slows down when the brakes are applied, or when the fan is turned on as well but to a lesser extent. I have an '09 so I would imagine they tend to do it from day one. Its a subtle feeling and for the most part not worth mentioning because it is harmless, but it does cause cause a slight vibration. If this is the shaking the poster was mentioning, I think its a non-issue.
as for the rpms...i defer to your numbers mainly cause I dont feel like going outside and checking (say they drop from 700 down to 550). my point was that parasitic loss is more noticeable on these little engines and the drop in rpm that occurs when a demand exists causes a slight vibration.
Old 01-18-2009, 02:08 AM   #14
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
It's normal. Don't worry.
Old 01-18-2009, 10:12 AM   #15
smofskra
smofskra's Avatar
Drives: 08 Flint Mica Sedan
Send a message via MSN to smofskra Send a message via Yahoo to smofskra
i feel my car shaking all the time but thats beacuse the stereo is up too loud
smofskra is offline   Reply With Quote
Old 01-18-2009, 11:01 AM   #16
YAR1S
YAR1S's Avatar
hahahaha .............
-Jen <3
Old 01-18-2009, 11:02 AM   #17
saplaymate
saplaymate's Avatar
Drives: 08' HB
Yes Yarises tend to become frightened around large vehicles, kinda like chiwawas!
0 - 60 in 3 shifts
saplaymate is offline   Reply With Quote
Old 01-18-2009, 12:36 PM   #18
gid
Smile
the anxiety passes .
Waiting for the Taiwan Yaris heybai General Yaris / Vitz Discussion 13 03-12-2006 07:26 AM
