TRD High Flow Oil Filters
I'm trying to figure out if TRD filters are worth it. I found two, one seems to have a better flow rate but I can't find figures. Flow rate figures would be nice, if someone could get them.
TRD High Flow Oil Filters, $12 PTR14-00000-05 TRD High Performance Oil Filter, 4 Cyl $10 PTR43-33010, 98% at 20 Microns Wix/Napa Gold 51394, $5 Max Flow Rate: 7-9 GPM Nominal Micron Rating: 19 Amsoil EAO09-EA, $15 98.7 percent at 15 microns Going to get Pennzoil Platinum 5W-30 after the break-in period, so trying to get a high flow, high efficiency filter. |
#2 | |
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Jansen.... I am also in the Toronto area.. Where you able to find a local supplier for the TRD oil filters??
thanks Quote:
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
TRD is a rebadged K/N oil filter......
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
![]() ![]() ![]() Drives: 2010 Mazda3 iTouring Join Date: Jun 2007
Sparks Toyota lists 2 different TRD filters for the Yaris, one has an actual picture (white can like K&N) the other one doesn't have a picture. It's kind of weird that they have 2 TRD filters, maybe one's better who knows???
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
A Napa Gold/Wix filter for $5...if you're doing 5K OCI with the Pennzoil Platinum, like I'm doing, no need to spend twice the money. The WIX filter is a very good, well constructed filter. Only difference at all with the WIX filter and the Wix built AMSOIL Ea filter is the media, because the AMSOIL Ea is a 25K/1 year OCI filter.
if you're not over-revving your yaris constantly (which means you're revving to 6500 for long periods of time) why would you need a high flow oil filter?
what's more important is the dirt-catching ability of the filter.
toyota
i dont get high flow oil filter.... isnt it high flow less dirt thats being filtered..dont get it.
#8 | |
but the lower the restriction the lower overall oil pressure you'll see.. by 1-2 psi.. not a big deal honestly, especially when you're running heavier oil in a forced induction application
#9 | |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
If the oil pump doesnt have an internal bypass relief, then the pump will force the filter to pass whatever it can pump - which means if the filter media is overwhelmed, the pressure will unseat the bypass valve in the filtercan, and NOW you got plenty of flow (though unfiltered). Hey, I suppose it doesn't have to be constantly filtered. Understand, on most cold starts under 20 deg F the filter is not working at all - its just bypassing until the oil warms up. The "gelled" oil just wont flow through the media. - the bro Last edited by TheSilkySmooth; 01-13-2009 at 01:10 PM. Reason: two thumbs typist |
![]() ![]() ![]() Drives: '07 Yaris Sedan 'S' Join Date: Dec 2008
does anyone have instructions for installation of fog lights on the 4 door yaris?
#14 |
Speaking of M1 filters, whom is the supplier? Still Champion labs or is it Hastings or wix. I heard it can vary by application. I's the M1 more restrictive due to a less porous "paper"?
#15 | |
i don't understand why people don't just stick to a "toyota" filter. they're inexpensive, of good quality (not just paper inside) and look great on the car ;)
#16 |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
+1 on that . Been using TOYO filters for years without an incident . Had good luck with GM oil filters as well . Used them and TOYO filters for '03 MATRIX , '99 PRIZM ( Corolla ) , 2000 PRIZM , and '99 Corolla . They're the same as used for the YARIS , 1st Gen XB , etc..
#17 | |
#18 |
Ended up using the WIX filters with Pennzoil Platinum, since I couldn't find any specs on the TRD filters.
| Motor Oil and filters | Lafiro | DIY / Maintenance / Service | 94 | 03-15-2010 03:40 PM |
| FS AEM CAI w/dry flow instead of oil filter | superfly78209 | Items for Sale by private party | 24 | 12-26-2008 10:43 PM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 04:27 PM |
| TRD Parts | MC-BPT | Sponsors Classifieds Area | 9 | 06-23-2007 10:51 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
