Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 01-13-2009, 11:23 PM   #1
NZYari
Drives: 2009 RS 1.8 6 Sp
Aftermarket Exhaust & Susp for TS (RS)
Had my RS (Euro spec TS) for 2 months now. Just wondering whats about in way of exhausts and suspension bits. As motor supposedly heavier, I assume front swaybar or strut brace would be difffrom 1.5l.
Now clocked 1200km, and loosening up. Only one hitch - at 460km all the rockers fell off inlet cam bank, with some parts retrieved from sump. - 3rd to happen I know of with this motor. Apart from that, all ok.
NZYari is offline   Reply With Quote
Old 01-13-2009, 11:41 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
that sounds rather scary to me , hopfully no other damage was done to the engine.
Old 01-14-2009, 04:26 AM   #3
NZYari
Well Toyota NZ says all should be ok. Although on startup it now seems to make little tapping noises. Will keep a ear out for these to see what happens. Was a bit of a shock - a loud 'bang' from motor, and then it was dead. And the head parts ended up in the sump! I saw motor in bits, and parts being found. As said, one dealership has had 3 of these motors do this, so not a one off. Maybe they have an assembly oddment.
I would have been happier for dealer to call and say "your car is ok, but we decided to replace it" At 460 km, would have been a good call.
Old 01-14-2009, 12:08 AM   #4
jinxor
jinxor's Avatar
Drives: Yaris 3dr YRS
same here... that sounds either too car technical or I am getting scared
Old 01-14-2009, 12:23 AM   #5
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Hi there and wellcome!
In regards to suspension you can use ANY suspension component intended for the NCP91 Yaris.
I'm currently using a set of Tein Coilovers from a 1.5 US spec yaris and they work great. Other TS owners are using the H&R springs and they work great.
I have the TRD rear sway bar for the US Yaris. It work wonders for this car.
You don't really need a front strut bar or a front sway bar. Non of those will make any good for your car...
Old 09-05-2010, 12:40 PM   #6
lammy29
Drives: Yaris
sounds sick... but don't wanna make my car noisy wen driving low speeds n motorway
lammy29 is offline   Reply With Quote
Old 09-20-2010, 06:29 AM   #7
NZYari
Lil Toymotor still rattling away. Seemed that at 10,000km engine freed up somewhat, seemed to be more responsive. Any hints on why this could be? Now for an update on header and exhaust options - Header will give power / torque increase, so who has that? Come on guys, someone must do it. Is the RS / TS 1800 an option in Japan JDM? If so, does anyone know any aftermarket parts there?
Old 09-25-2010, 08:36 PM   #8
lammy29
Drives: Yaris
http://www.remusuk.com/model.asp?id=...0II&man=Toyota
thinkin of gettin that but gotta find sumone to fit for me. garm sells headers but will they fit our engine?
Old 11-08-2010, 09:02 AM   #9
NZYari
Now at 15000km and in Japan for just a few days. Are there any parts here in Japan worth considering, as 1800 not sold here? Suspension bits, anti roll bars etc? Hope someone can assist with JDM???
Old 11-11-2010, 03:04 PM   #10
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
most JDM will bolt straight on , pick up a TRD sway bar
Old 11-11-2010, 11:21 PM   #11
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
how about a Vitz cup car?
Colin Chapman disciple
Installing a aftermarket exhaust shameer_k Performance Modifications 2 11-21-2008 10:26 PM
Aftermarket Exhaust; More Power? myt Performance Modifications 23 07-29-2007 03:18 PM
A good aftermarket exhaust... whooppee777 Performance Modifications 4 04-06-2007 02:12 PM
What aftermarket exhaust will fit the Yaris Sedan? dngz Performance Modifications 2 10-02-2006 01:41 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
