Old 01-21-2009, 03:12 PM   #1
jrenter
Drives: 2007 Toyota Yaris 4door
Problems with my yaris in winter
I just wanted to see if anyone else had problems with their Yaris on the snow and ice? I'm from Alberta Canada where we get a fair amount of snow and ice. Right now though the snow has melted and the ice has stuck around! I live in an apartment building and can barely get out of our parking lot safely without my yaris sliding all over the place. Should I put more weight in the trunk to weigh it down a bit? What's the best option? I do have snow tires on my car but even trying to get out my parking lot, I'm doing maybe just above the 10/km hr mark on my speedometer and I can't control the car at all.
jrenter is offline   Reply With Quote
Old 01-21-2009, 03:47 PM   #2
MUSKOKA800
MUSKOKA800's Avatar
I've found my ice radials to be the ticket.
Most tires, even some all-seasons, can negotiate snow. Few tires can cope with ice / hard packed snow with confidence.
Old 01-21-2009, 04:20 PM   #3
Forrest
Drives: 08 LB BLACK
Isn't your landloard/apartment owner responsible to keep the parking area safe? If someone gets hurt, he gets sued. You and your neighbors should all complain.
Forrest is offline   Reply With Quote
Old 01-21-2009, 04:38 PM   #4
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Alberta, Canada...... what snow/ice tires do you have on the Yaris? If you are running stock tires......... don't.
Old 01-21-2009, 05:01 PM   #5
Doug007
Doug007's Avatar
Drives: 2007 Yaris S Sedan
Spikes-Spiders
Bailout wrote about these last year and I bought a set. Very effective in snow and ice as well as easy on/off:
http://www.spikes-spiders.com/
2007 Silver Streak Mica Yaris S Sedan 5 Speed
dojo TSUKAMI Shift Nob
Brake Light Pulser
Daytime Running Lights
http://www.webelectricproducts.com/products.htm
Doug007 is offline   Reply With Quote
Old 01-22-2009, 02:48 PM   #6
blktiger60
blktiger60's Avatar
Drives: `08 HB S
Spike Spiders are $500 a set - not an option for me.
- The Black Ship Yaris -
blktiger60 is offline   Reply With Quote
Old 01-22-2009, 08:47 AM   #7
Return of the Yarii
Drives: 2007 Sedan S
^^PK must be the only one who DOESNT have problems on snow and ice. The OEM tires (RE92's) are horrible in winter. This is now my 2nd Chicago winter w/the Yaris and learned my lesson after the 1st one to buy a dedicated set of winter tires (bought a set of 4 Winterforce tires from TireRack this year) and honestly they made a world of difference. Chicago got hit very hard this winter and I was able to navigate even the worst snow and ice covered roads w/the snow tires on with ease.
Return of the Yarii is offline   Reply With Quote
Old 01-22-2009, 02:51 PM   #8
blktiger60
blktiger60's Avatar
Drives: `08 HB S
A few weeks ago we got SIX feet of snow in less than 14 days. I took off my customs and put back on the stock wheels and tires. I didn't have any problems driving on them.
Old 01-22-2009, 02:59 PM   #9
blktiger60
blktiger60's Avatar
Drives: `08 HB S
Just so you know, I bought my Yaris in Denver last winter and drove it home, 1600 miles over several moutain passes. The worst one being the one just outside Jackson Hole Wyoming, 7% grade packed snow and ice and snowing at the time I drove over it. I was following two SUV's that never did pull away from me. I did do a bit of a "drift" around the first hairpin corner because I was traveling too fast to not slide. Still, having had many years driving in winter conditions I didn't see this as a problem, I just slowed down a bit.
Old 01-23-2009, 12:14 PM   #10
rcturner
Drives: Yaris Liftback
Cool
Mine does well in the snow but is really bad on ice.
rcturner is offline   Reply With Quote
Old 01-23-2009, 12:39 PM   #11
REM
REM's Avatar
Drives: 2012 Nissan Leaf SL
Yeah, before I got snow tires I got stuck in a parking lot and ended up putting it in N and pushing it out of the parking lot. I did it all by myself; an advantage to having a small car.
Cheers,
Ryan
REM is offline   Reply With Quote
Old 01-22-2009, 09:42 AM   #12
fearturtle44
Drives: S Flint Mica
Do not put weight in back of car. Defeats the purpose of Front Wheel Drive. Also, the Yaris is not a snow/ice car. 4WD are snow vehicles. No vehicle is good on ice.
No compact car is going to get good grades for winter driving.
Just have to drive more slowly, take your time on turns, and watch out for the other drivers.
fearturtle44 is offline   Reply With Quote
Old 01-22-2009, 01:55 PM   #13
Dorkinheimer
Dorkinheimer's Avatar
Drives: Yaris 2007 *manual*
Don't add weight to your car, you'll lose 5 mpg or more.
Maybe your tires are inflated too high.
Get winter tires, the rubber is softer and has a better grip on ice.
Dorkinheimer is offline   Reply With Quote
Old 01-23-2009, 01:23 PM   #14
ddongbap
I could swear theres a post about this every week.
Solution: I'll get some tires with those spikes like the football shoes have. The metal ones.
Old 01-23-2009, 11:46 PM   #15
Dbeau
Dbeau's Avatar
Drives: 2007 Yaris Sedan Aero
Wow another Yaris owner in Alberta !
Anyway its my first winter here in Calgary and I have the sedan with winter tires. The only issue I have found is that the car is so damn light and the motor included doesn't really weigh the front wheel drive enough to get traction on a start. Kinda got to be easy on the throttle to get goin but once moving..all is good.
But to be honest you sorta get used to it and do it without thinking about it.
Dbeau is offline   Reply With Quote
Old 08-21-2009, 11:25 AM   #16
glhsracer
Drives: 2008 Sedan MT
I found winter driving on the original tires wasn't too good either. I would think this is a common problem of any light weight car with road tires. When it gets too deep here in Michigan I drive my Tacoma 4x4 truck. I know it is kind of wimping out but it is much safer for me and those around me.
glhsracer is offline   Reply With Quote
Old 08-22-2009, 05:04 AM   #17
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
The original tires on my 08 sedan were Goodyear summer tires,i wouldnt dream of trying to drive in winter with them,Bridgestone Blizzaks work well.
Old 08-21-2009, 11:43 AM   #18
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Move south. Far south.
Interesting Info on the Yaris from AU mikeukrainetz General Yaris / Vitz Discussion 3 11-24-2006 09:18 PM
Test Drive: Yaris revolution ketel0ne General Yaris / Vitz Discussion 0 08-04-2006 10:13 AM
