Old 08-12-2006, 01:26 PM   #1
Henshin
a go-go!
Henshin's Avatar
Drives: Silver 07 HB - 5spd
LB: non-destructive Front License Plate mounting
Hey everybody, I've been planning on doing this since I got my car, but haven't had the time or a simple solution. Thanks to my friend Hulles I decided to do it today...
I went to home depot and bought a bunch of items I thought I might need (pic 1)
in the end, I only needed 2 items:
a 1/4" X 3.5" Bowl to Floor Toilet bolt set (that's right) $2.16
and a roll of non-adhesive plastic shelf and drawer liner $4.97
Then i cut the liner (only needed 1 cut, because the width was = to the size of the plate) and took the plastic washers out of the toilet bolt set and attached the plastic to the tags. (there is a ton of plastic liner left over)
then I used the metal washers and brass nuts that came in the toilet bolt set to mount the plate through the lower grill. The hardest part was getting inside the grill from the bottom, had to loosen the plastic engine bay protector and slip my hand up in there.
only takes a couple of minutes.
perhaps I'm the only one that didn't want to punch holes in their bumper and no one else will find this useful, but i'm happy with the results.
Henshin is offline   Reply With Quote
Old 08-12-2006, 01:53 PM   #2
Alexandre2k3
Drives: Yaris liftback
da da da dammit, wished i had speacial ordered my LB and told them not to drill friggin holes then i could have done that... oh well good idea
Alexandre2k3 is offline   Reply With Quote
Old 08-12-2006, 01:56 PM   #3
rstb88
rstb88's Avatar
Drives: Silver Hatchback
mine came off the showroom floor and din't have predrilled holes ;P
"Automatic carwashes are like Hookers........are you sure you want to use it next???? (Jer)"
rstb88 is offline   Reply With Quote
Old 08-12-2006, 09:07 PM   #4
johnnyfive
johnnyfive's Avatar
they were going to not put holes in my bumper, but ended up getting the car from another dealership, and they had already put them in...
johnnyfive is offline   Reply With Quote
Old 08-13-2006, 06:02 AM   #5
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
That sucks, here in KY, front plates aren't even used.
paultyler_82 is offline   Reply With Quote
Old 08-13-2006, 07:30 AM   #6
PixieDawn
Drives: Yaris 2007, Eclipse 2000
not used in fl as well !!!LUCKY US...
PixieDawn is offline   Reply With Quote
Old 08-13-2006, 12:19 PM   #7
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
I'm happy because we don't have front licence plate in Quebec!
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 08-13-2006, 01:08 PM   #8
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
tu francais simmz? :p
OxyG3nE is offline   Reply With Quote
Old 08-13-2006, 08:39 PM   #9
SimmZ
Certain!
Old 08-13-2006, 07:33 PM   #10
Henshin
a go-go!
Henshin's Avatar
i already got told by a cop to put it on... it was less than a month of driving with no plate... I knew i'd have to do it eventually... so here's my solution.
Old 08-30-2006, 12:12 PM   #11
autophile
Drives: '07 HB Manual Yarrrrris
Thanks, Henshin, I just got my Yaris last night, and was wondering how to do this nicely. Maryland also requires front license plates. My other car came with me from Delaware ten years ago, where you didn't need a front tag. I figured that the expense and damage to put on a front tag was worth getting tickets over. Then I got pulled over a few years after I moved, and it just wasn't worth the hassle :/
Thanks again!
--Rob
autophile is offline   Reply With Quote
Old 09-03-2006, 05:30 AM   #12
IsLNdbOi
IsLNdbOi's Avatar
This is what Nevada's DMV says about front plates:
Most vehicles require two plates at all times, except motorcycles and trailers, which require only a rear plate. You must display both plates if the vehicle is designed for a front plate or if the manufacturer offers an add-on bracket or frame.
Front plates are optional only if 1) the vehicle was not designed for a front plate and 2) the manufacturer did not provide an add-on bracket or other means of displaying the front plate.
(NRS 482.275 - 2005 Nevada Legislature Senate Bill 251)
DMV will issue two plates for all vehicles (except motorcycles and trailers). If the second plate is not displayed, it is the owner's responsibility to store the second plate and surrender or return both plates to the department at the appropriate time.
My LB Yaris doesn't seem to have any mounting spots for a license plate on the front. Do you guys think I fall under the front plate optional policy?
Old 09-03-2006, 08:24 AM   #13
tomjasz
tomjasz's Avatar
Drives: 07 Black Yaris LB, 05 Camry LE
I've lived in Las Vegas for 20 years and haven't had a front plate displayed in 12 years. So far no hasslles...
Wife doesn't hang a front plate either!
tomjasz is offline   Reply With Quote
Old 09-03-2006, 01:09 PM   #14
IsLNdbOi
IsLNdbOi's Avatar
Thanks!
Old 08-12-2006, 03:07 PM   #15
Henshin
a go-go!
Henshin's Avatar
Originally Posted by echo_hrs
Great idea to protect the bumper, I'm not thrilled with the placement, IMO it should be centered...
Cheers
yeah, that's one good thing about doing it this way, you can put it anywhere... i prefered off-center, so...
and i had to fight to get out of the dealer without holes or a front plate... but it was worth the hassle!
removing front plate Lowfront Cosmetic Modifications (Exterior/Interior) 19 08-25-2006 09:59 PM
