Old 01-24-2009, 01:36 PM   #1
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
How to fix a flat.
http://www.metacafe.com/watch/233717..._damaged_tire/
Old 01-24-2009, 02:04 PM   #2
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Common method for baloon tires..... starter fluid and a lighter ....... method has been used for years
Old 01-24-2009, 03:38 PM   #3
nemelek
DWEED
nemelek's Avatar
My borther-in-law does that with the tires on his semi.
Old 01-24-2009, 10:37 PM   #4
That method scares me. A while back, I ran into a write-up on using a ratcheting nylon strap to squeeze the tire enough to seat the bead - It works like perfectly and you get to keep your eyebrows.
Old 01-24-2009, 11:39 PM   #5
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
Are you serious? This is too gangster.
Sponsored by: Micro Image
http://microimageonline.com
Old 01-25-2009, 12:19 AM   #6
MadMax
MadMax's Avatar
The video's been removed, but I am sure it is the same method I've seen used numerous times on the trail with Jeeps. Sure, it's not the safest thing to do; but you do whatever it takes to get you home!
Cheers! M2
Old 01-25-2009, 12:48 AM   #7
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
what happened in the video?
Its a Chao!!!
Old 01-25-2009, 02:15 AM   #8
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
what is it physics or chemistry?
pour some HIGHLY flammable liquid into a tire throw a match it will 'explode' pulling all available oxygen for burning into the tire thusly causing a vacuum effect all this happening in milliseconds and causing the tire to seat itself from the force....
Old 01-25-2009, 07:59 AM   #9
Just hit the play button. It says that the video has been removed, but when you hit play it does...
DIY- rattle from lower windshield fix. PetersRedYaris DIY / Maintenance / Service 3 08-21-2011 12:29 AM
Probably a dumb question - Flat spots 33OH Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-22-2008 01:41 PM
Flat Key MadMax General Yaris / Vitz Discussion 24 11-07-2008 06:40 PM
question about lb fold flat seats roxy84 General Yaris / Vitz Discussion 7 05-29-2007 01:07 PM
Flat Black Steelies With Red Pinstripe? blacksan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-21-2007 05:25 PM
