Old 01-24-2009, 02:29 PM   #1
BrazdonW
What kind of car is that?
Drives: Yaris 3d liftback
extended studs
does anyone know how difficult it would be to install extended studs on the yaris?
Old 01-24-2009, 03:28 PM   #2
dexter_5000
dexter_5000's Avatar
Drives: 2006 Scion xA
Send a message via AIM to dexter_5000
i would imagagine as easy as the xa and xb. you need to find someone who makes longer studs first.
dexter_5000 is offline   Reply With Quote
Old 01-24-2009, 05:26 PM   #3
ddongbap
ARP.
Old 01-25-2009, 03:38 PM   #4
BrazdonW
I'm not having trouble finding the studs
i would like to know how to install them
Old 01-25-2009, 03:54 PM   #5
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Why Why Why ?????? Do you have some bad-ass turbo'd out yaris that you need to install some big slicks on the front ? I had a full drag fwd dsm that I installed arp's on the front . On that I had to take off the front hubs and you either need to use a press to knock the studs out/re-install or just bang them ef'er out with the BFH(bigg fancy hammer lol) and press the new one in with a vise and some blocks , very primitive way of doing the job , but its all I had , install way free , and it worked .
Old 01-26-2009, 01:21 AM   #6
ddongbap
You can never have too much grip.
Old 01-25-2009, 04:00 PM   #7
BrazdonW
lol i am actually trying to add more thread to the rear so i can put my spacers on to make the rear wheels flush with the fender and still be able to turn the lugs enough for it to be safe.
so i need to install them with a drum set up :)
Old 01-25-2009, 04:03 PM   #8
blacksandiegovitz
Drives: 08 Vitz
HA Ha thats so funny , I didn't even think about the longer studs for more rear offset. Pretty much the same a the front you take the drums apart/off a knock the studs out the hub .
Old 01-25-2009, 04:59 PM   #9
BrazdonW
what are some things i should be careful of?
Old 01-25-2009, 05:40 PM   #10
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
hitting your fingers with a hammer, sorry ,
but that is the truth , replaceing studs is real easy.
Old 01-25-2009, 05:37 PM   #11
dngz
dngz's Avatar
Drives: black yaris sedan
i tried replacing the studs in the rear to add spacers myself. it's quite the job. i took the whole drum apart and knocked the studs loose but couldnt slide them out. i didnt want to take apart my whole drum myself cuz i didnt want to be messing around with the brakes because i have no idea how to do it. so then i brought it to the shop and they took a look and said they would have to take off the whole drum brake itself. quoted me quite a bit of money to change the studs... maybe if i ever convert to rear disc ill get em done at the same time hehe
dngz is offline   Reply With Quote
Old 01-25-2009, 07:45 PM   #12
dngz
dngz's Avatar
i hammered them loose and there is no way of getting those studs out. even if there was a way, good luck putting longer ones in...
Old 01-25-2009, 09:27 PM   #13
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
I usually use a torch to heat them up first then they come right out lol.
Old 01-25-2009, 09:55 PM   #14
tk-421
tk-421's Avatar
Drives: 5D-07-LB
@BrazdonW: How big are the spacers that you got?
I'm thinking about getting 10mm hubcentric spacers... I shouldn't have to worry about the studs, right?
Old 01-25-2009, 10:49 PM   #15
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
^ rear 10mm spacers....u need longer studs for this part!
Old 01-25-2009, 11:23 PM   #16
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Thx Malaya!
Old 01-25-2009, 11:25 PM   #17
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
I'd also like to add( since i just did 2 subaru's this weekend for extended arp wheel studs)
that it helps to put the new studs in the freezer the night before. This aids in putting them in, as they warm, the metal expands. G/L!
anonymous user is offline   Reply With Quote
Old 01-26-2009, 02:57 AM   #18
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
where do u get the hub spacers?
extended warranty... yes/no? TinyGiant General Yaris / Vitz Discussion 42 09-01-2009 01:43 PM
Extended Service Packages Shadowbeast New YARIS Purchase Forum 1 01-16-2009 11:30 PM
Found a good deal on extended warranty Bretsuaz New YARIS Purchase Forum 1 05-02-2007 10:40 PM
Extended warranty worth it? oni5000 New YARIS Purchase Forum 17 09-04-2006 04:19 PM
Extended Service warranties! Buckethead New YARIS Purchase Forum 31 07-29-2006 07:46 PM
