Old 01-28-2009, 11:50 AM   #1
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
215/45/17 on stock suspention ,want to verify
Hey guys,
Finally getting some new wheels for my '07 Sedan
Looking at some 17" but im thinking of running 215/45/17 Nankang tires
I Dont see those measurements on the list in the guide
All Input welcome and appreciated
Arkhangel is offline   Reply With Quote
Old 01-28-2009, 11:50 AM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
its good!
Old 01-28-2009, 11:52 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
most likely rub, depending on your offset
Old 01-28-2009, 11:59 AM   #4
Arkhangel
Arkhangel's Avatar
ok so more info needed??These are the Wheels Evoke 17 x 7 +40 offset
Old 01-28-2009, 12:03 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
wow, $350 shipped for 4 new 17" wheels?
hmmmmmmmmmmmm (where's Russel teh Pirate???)
maybe try 205 45 17?
Old 01-28-2009, 12:04 PM   #6
Arkhangel
Arkhangel's Avatar
so you think 215 will rub?
Old 01-28-2009, 12:08 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
Old 01-28-2009, 12:12 PM   #8
Arkhangel
Arkhangel's Avatar
im thinking of 215 cuz i like the wider tire
Old 01-28-2009, 12:13 PM   #9
kimona
kimona's Avatar
Drives: 2014 White VITZ
215/45/17's on stock suspension should work okay, but you may get a little rub up front lock to lock. Problem is, they'll poke out up front on ET40 and won't look like a proper fitment. I'd stick with OEM size 205/45/17.
Old 01-28-2009, 01:15 PM   #10
Arkhangel
Arkhangel's Avatar
ET40??
Old 01-28-2009, 01:37 PM   #11
kimona
kimona's Avatar
You indicated an offset of +40mm.
Old 01-28-2009, 02:14 PM   #12
Arkhangel
Arkhangel's Avatar
Gotcha ;)
Old 01-28-2009, 03:16 PM   #13
Split
Drives: 2008 Yaris Sedan
Exclamation
the higher the offset the less chance of rubbing. +43mm is the minimum offset to run in these cars to prevent rubbing lock-to-lock, over bumps, or on lowered suspension. I'm on a quest the find the lightest wheels that are +43mm or higher in 16x7.
Split is offline   Reply With Quote
Old 01-28-2009, 03:39 PM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
the higher the offset, the more chance of rubbing "inboard" don't go overboard with your search for "high" offset wheels.
and in the grand scheme of things, does 3mm really make THAT much difference?
Old 01-28-2009, 06:06 PM   #15
kimona
kimona's Avatar
OEM offset is +51. OEM tyre size is 195/50/16.
With 205/50/16 rubber, you can generally run +42 safely with no up-front poke and no rubbing.
With 195/50/16, you're generally safe with +38.
To answer Tamago's question: Yes, a couple of mm's makes a significant difference on these cars.
Old 01-28-2009, 10:47 PM   #16
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
You are correct, but all of which you have posted is really dependant on the wheel width, which you have not listed.
Also, OEM 16's don't exist, 15's or 17's only. What is the width of the +51 offset OEM wheel? I'm guessing 5.5 or 6 inches for the 15's and 6.5 for the 17's???
Old 01-29-2009, 06:44 AM   #17
kimona
kimona's Avatar
These are the OEM wheel sizes, offsets, and tyre sizes:
14x5, ET45, 175/65/14
15x5.5, ET45, 185/60/15
16x6, ET51, 195/50/16
17x6.5, ET51, 205/45/17
TRD Option 18x7.5, ET42, 215/35/18
Old 01-28-2009, 06:00 PM   #18
I have 17x7" with an offset of +40, and 205/40/17 tires. I'm lowered on S.Tech springs, and get minimal rub on freeway dips. I don't get lock-to-lock rub tho, which is strange, but I'm not complaining.
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
