![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Anyone else get a heat shield/exhaust rattling from under the car?
I keep getting this slight rattling or squeek sound from under the car and it sounds like the heat shield or somewhere along the lines of exhaust. It seems to squeek a little more when I put it into gear then when it's in N or P. My guess it does that because the idling is a little bit different so it would cause it to squeek more or less.
![]() ![]() ![]() Drives: Blazing Blue Liftback Join Date: Oct 2008
Same here, I think it's a cable or something rubbing.
There was a topic about this but I can't seem to find it. |
I don't think it's so much the cable vibrating but has that squeek sound like when there is loose exhaust or heat shield. It might might very well be that cable but I'm leaning more towards the other .
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Maybe your brakes?
![]() ![]() ![]() Drives: 2010 Mazda3 iTouring Join Date: Jun 2007
someone posted a couple days ago that it was a TSB regarding the shifter cable, Toyota's fix was to put a zip tie around the cable or something to that effect, I'll see if I can find that post.
The Martian
I have actually had my heat shield rattling on my exhaust...The sound is definitely not a squeak, it sounds almost like a small hole in the muffler. Just jack it up and look^-^
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker. |
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 31 | 10-20-2025 09:08 AM |
| Photo Scavenger Hunt Ideas Thread | Black Yaris | Photo-Video-Media Gallery | 41 | 02-28-2009 08:54 PM |
| YW photo scavenger hunt... what do you think | Black Yaris | Photo-Video-Media Gallery | 47 | 02-02-2009 07:29 PM |
| Someone Please Help With SET & Local Dealer Nightmare! | sanityassassinv2 | General Yaris / Vitz Discussion | 32 | 11-26-2008 11:32 AM |
| Buying a first car..lol | Blenjar | Off-topic / Other Cars / Everything else Discussions | 11 | 06-13-2006 11:58 PM |
