Old 02-11-2009, 06:25 PM   #1
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Replacing headlight bulbs
Is there a DIY on this subject. I have a LB and I'm having a hell of a time!
I NEED HELP!
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 02-11-2009, 06:38 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i believe bumper has to be push out a bit.. 4 screws on top and snap clips on the side.
Old 02-11-2009, 06:55 PM   #3
nemelek
DWEED
nemelek's Avatar
As I recall the bulbs can be pulled out from behind the assembly. There is a 2 1/2 inch rubber sleeve that will come off also. The space is tight to work in.
Old 02-11-2009, 06:59 PM   #4
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
it's super hard and you'll scratch your hands up! good luck
Old 02-11-2009, 07:08 PM   #5
ddongbap
Its a mission+1/2.
Old 02-11-2009, 07:26 PM   #6
nsmitchell
nsmitchell's Avatar
I know. I already have bloody knuckles. I am having troubles pulling the rubber boot off. I have the connector off. I took screws out of my headlight to try to give a little more room. What a friggin PITA!
Get YarAss in gear!
RIP - Casey Tatum
Old 02-11-2009, 08:44 PM   #7
nsmitchell
nsmitchell's Avatar
Well, it's done. Word to the wise... Take the bumper cover off and it's easy. Taking the bumper cover off is relatively easy as well.
Get YarAss in gear!
RIP - Casey Tatum
Old 02-12-2009, 03:42 AM   #8
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I cant believe all that work is necessary just to change the headlight bulbs,on my sedan i could change both head lights in a couple of minutes with nothing more than the last 2 steps in your pictured process. are HB's that much different?
Old 12-10-2010, 10:51 PM   #9
nsmitchell
nsmitchell's Avatar
Pretty cool that I'm coming back to the forum to get info on changing headlight bulbs and stumble upon my own post! My Yaris is still running perfectly!
Get YarAss in gear!
RIP - Casey Tatum
Old 02-12-2009, 04:17 AM   #10
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
I'd have to say it's a little different. It's better to remove the clips, but the bumper does not completely have to come off.
808_Yaris is offline   Reply With Quote
Old 02-12-2009, 12:20 PM   #11
nsmitchell
nsmitchell's Avatar
Taking the bumper off is quite easy. I prefer that method to the "squeeze your hand into a tight space and shave skin off" approach. Plus, once the bumper cover is off, you can see how much room there is for an intercooler! ;) You can also replace your stock horn with a louder beefier one.
I will never do the scraped knucle method again.
Get YarAss in gear!
RIP - Casey Tatum
Old 02-12-2009, 12:22 PM   #12
nsmitchell
nsmitchell's Avatar
just pull hard on the sleeves they are harder to take off than to put back on. and yes bloody knuckles are a must. the worst one is the left hand one because of the fuse box. but it can be done and once you get the hang of it its quite easy the next time
The rubber boot on mine was friggin impossible to get off the bulb, even with the bulb/boot in my hands. I used a chopstick to pry it off. (i used something dull and plastic so I wouldnt tear the rubber)I put silicone on the boot so it will slide off next time.
My New Osram Silverstars will be here in a week or two, so I will have to repeat the process.
Get YarAss in gear!
RIP - Casey Tatum
Old 02-12-2009, 12:26 PM   #13
Morgan
Morgan's Avatar
Drives: 07 MM LB
I didn't have to remove the bumper to change out headlights or fog lights...
Old 02-12-2009, 12:49 PM   #14
nsmitchell
nsmitchell's Avatar
How the hell did you do fog lights without removing the bumper cover?
That would seem impossible. Did you remove the plastic shields from under the engine? If you did, you were about 30% done removing the bumper. I think it's so easy, why not. My big hands do not fit well into that tiny little space. Besides, Toyota reccomends taking the bumper off to replace the bulbs for hatchbacks.
Get YarAss in gear!
RIP - Casey Tatum
Old 02-23-2009, 09:26 PM   #15
Morgan
Morgan's Avatar
Drives: 07 MM LB
go from the under the weather shield and reach?
yeah small girly hands ftw :D
*edit oh and some of the shield pulls away when you remove a few screws from the bumper... I'll try to get pictures tomorrow of what I did since mine need to be replaced anyway
Old 03-20-2009, 07:33 PM   #16
Sideways02
Drives: 2008 Yaris HB
I'm glad I found this place. I tried replacing my bulbs with some brighter ones and i couldn't figure out how to do it. Now that I have some knowledge, i might attempt it again. those rubber seals are a pain in the neck!
Sideways02 is offline   Reply With Quote
Old 03-20-2009, 08:40 PM   #17
I replaced mine with Silverstar Ultras by removing the bumper for access. I posted some pictures of the process in this thread:
http://www.yarisworld.com/forums/sho...ght=silverstar
Old 02-14-2009, 09:13 PM   #18
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
I hear few months ago that sedan headlight was extremely easy to take off...well...I still prefer my hatch!
the_boss is offline   Reply With Quote
how to change headlight bulbs? PETERPOOP DIY / Maintenance / Service 57 05-01-2016 05:06 PM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
Replacing a headlight (X Reg Yaris) Help pls *Cooperman* DIY / Maintenance / Service 0 09-23-2007 03:14 PM
Yellow, Purple, Green Headlight BULBS? jamal1984 Cosmetic Modifications (Exterior/Interior) 12 02-04-2007 08:30 AM
