Old 02-15-2009, 02:40 PM   #1
abdallah380
Fly Emirates :)
abdallah380's Avatar
Drives: 2010 Yaris Sedan
rough surface...
hey ppl, i noticed while washing my yaris sedan... the part of the body below the doors, the lowest part where there is paint. kinda feels rough... i dont think its rough, but the surface is rough. is that normal? just above the ground, below the doors...
abdallah380 is offline   Reply With Quote
Old 02-15-2009, 02:54 PM   #2
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
normal. all cars are like that
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 02-15-2009, 02:57 PM   #3
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I think there is some sort of textured finish applied in this area underneath the paint. Probably for weatherizing/rustrpoofing and to prevent all those pebbles and road debris from exposing the metal underneath.
Old 02-15-2009, 06:40 PM   #4
SeaYa
Is about to 'SeaYa' later
SeaYa's Avatar
Drives: 08 MT Sedan
Yep, this can be normal. Pretty sure in this case it's where the undercoating and basecoat happen to overlap a little. There are generally two explanations for paint roughness: One is paint sag, which is when the basecoat does not adhere well to the primer, and runs a little before it is cured, leaving little ridges. This is a quality issue with the paint, and would show up over the whole car if it were the case. Two is excessive film build (like when you spray paint and move too slowly). Spray technology has come a long way (most cars only need 2.5-3 gallons to coat now) and things like excess film build can be avoided, even in tough to paint areas, like the door jambs and trunk lips, but since it is a low point, with a sharp angle you may still get some excess build.
SeaYa is offline   Reply With Quote
Old 02-15-2009, 10:00 PM   #5
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
It's a chip guard applied at the factory.
Old 02-16-2009, 07:55 AM   #6
SeaYa
SeaYa's Avatar
Drives: 08 MT Sedan
Bob, I'm curious. Do you know which layer this gets sprayed on? Between basecoat and clear?
Old 02-16-2009, 01:09 PM   #7
abdallah380
Fly Emirates :)
thanks for the reply, u guys :) much appreciated... i have checked on few other yaris as well, they all have it too..
Kids have it sorta rough today GeneW Off-topic / Other Cars / Everything else Discussions 5 10-19-2008 01:21 AM
Is the Yaris engine a little rough? thomasward00 General Yaris / Vitz Discussion 23 04-30-2007 12:17 PM
Rough Idle in drive toyoman NY / NJ/ CT / PA 8 04-22-2007 03:40 AM
Rough edges? jmew0ng Wash, Wax, Detailing, Exterior Repairs 2 09-14-2006 07:34 PM
