§†ęĄ¶‡Ћ-NCP96
Soda vs Cement
I have a friend at my work, who used to work for pepsi in a distribution plant.
Monday morning they were loading some pallets of pepsi into a truck to be delivered but the fork lift accidentally poked a hole in one of the crates of pepsi and it leaked out, they said they were running behind so they just picked it up and set it in the corner of the warehouse and kept working while it slowly leaked soda out. There were about 50 packs of pepsi on the pallet fyi. Friday morning they went to the corner to go clean it up and they said when they lifted the leaking pallet off the ground all the soda had chewed away the top of the cement! She no longer drinks soda. |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
I would have to see it to believe it.
Making a decision without following it with an action is still a fantasy. |
§†ęĄ¶‡Ћ-NCP96
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
We were always told to put an iron nail in a glass full of Coke and let it stand for a week. It would dissolve. But the contents of your stomach are more acidic...
Cheers! M2 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
What's interesting is that the all natural and organic colas don't do this. If you take away the totally unnecessary and harmful ingredients found in Coke and Pepsi such as high fructose corn syrup, aspartame, phosphoric acid, sodium benzoate, etc. then the caustic reactions that are known to eat metals, teeth and now concrete sealant simple cannot occur.
The organic and/or all natural colas use ingedients such as evaporated cane juice and omit "flavor enhancers" and preservatives. It is a much smarter, healthier way to make a soda. But the big bottlers aren't interested in your long term health. They care only about how much profit they can show for this quarter, and each time you buy one of their products you help perpetuate this harmful behavior.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#6 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
it's a shame that the small timers can't get mass produced and pushed like the big timers..... vending machines on every corner for pepsi and coke.....yet I have to travel like 10 miles or so to get the good stuff..... |
#7 | |
Drives: 2008 Yaris Join Date: Oct 2008
Purer ingredients tend to reduce spoilage. Pure ingredients are easier to purge of bacteria and fungi during the process of concentration. "Natural" ingredients contain enzymes and reducing sugars that can corrupt stored foods. Pure Sucrose is a wonder food. If you keep it dry and away from air it stores very well. In contrast Turbinado (dried cane juice) and brown sugars are more fragile and do not store as well. Alas, the price of Sucrose is "supported" by Congress, hence the use of corn based fructose syrups that are well tolerated by many consumers. Artificial flavorings are aldehydes that are engineered for a certain taste. Considering that "natural flavors" are relatively scarce, fragile and often seasonal artificial flavors reduce the cost and increase availability of some tastes for more people. Artificial sweetners are subject to reasonable amounts of testing, and can liberate diabetics and others from the scourge of tiny portions and glucose spikes. I have to wonder how much of their negative press is inspired by the Sucrose Lobby, which works hard enough keeping Corn based sweetners at bay? However it's everyone's right to go to a Health Food store and pay half again more or double for something that does not store as long as the mass produced good and if its not well cared for can become a culture media. I'm not being hard on you Brian but don't you think there was a reason that so many moons ago the Food Industry wanted longer shelf lives and a wider market? Gene |
#8 | |||||||
From http://www.curezone.com/forums/fm.asp?i=1181971: Quote:
They are? By who? Where? When?! Would that be the same FDA that allows things like Splenda on the market even after it is proven that even moderate usage of it has the potential to cause cancer? Quote:
If you have no problem with any of that then, by all means, go drink your artificially sweetened and preserved soda and eat your bleached bread and your dyed cheese and wipe your ass with chlorine bleached paper. They will love you for it.
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
So I guess it's possible to dissolve a tooth in cola then? Or is that just the cavity working?
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#10 | ||
#11 | ||||||||
I bet you also get a good heaping helping of benzine just driving down the highway, because incomplete combustion will seed it all through the air. Catalytic converters in combination with ethanol also generate formaldehyde, a far more potent carcinogen than benzine. IF you eat organic you may or may not be consuming fungi which generate carcinogens naturally. Modern farming methods can eliminate the fungus but organic farmers... well, I don't know how they do it. Quote:
The longer that food can be stored the less waste of it. While organics will work if you leave them in their natural state when you turn them into bread, pasta and other "processed foods" they have short shelf lives. That's the reason that the industry did all of that refining! It costs money to refine food, so there had to be a damn good reason to do it! If you're a poor person - not all of us work in IT - then it behooves you to have decent quality food, not whatever spoiled crap is seconded off to you. I swear, Brian, you've had it too well for too long. You've lost touch with people and what they have to do to make it out here. Me? I'm doing okay but I don't forget what it's like to be hungry. To not know where my next meal is coming from. I bet our posters from the "third world" know this one real well. You ever been hungry, Brian? No, not when you were out on the trail or in the bush, but you're out of money and you don't know what you're gonna do. That's hungry. A few million kids will go to bed hungry tonight, and their parents will hurt too. Thank God for white flour and white rice. Quote:
Some modern food processing bugs me, such as feed lots, lariage (that's how long the animal sits starving while it waits to be "processed", and of course my personal gripe, putting antibiotics and hormones into perfectly healthy animals. Other things, like no till farming, and other modern methods are great. They make food cheap and plentiful. If genetic engineering were handled a bit more reasonably I'd be for it too. Quote:
So either the FDA isn't doing their job, they've been "bought off" or the evidence is still weak. Be nice if in fact the FDA was so easy to sway that they would move a little faster approving drugs. I am not convinced about Splenda, but then again, I don't use it. I do know some diabetics who swear by it. You know anything about diabetes, Brian? Quote:
Why don't you move close enough to work so that you don't have to drive, so you can ride a bike or walk to work? Why are you working in IT? Why aren't you living off of the Grid if you're so worried about "the health of the planet"? Why are you consuming electrical energy online? You don't have to live like Ted Kaczinski, but really, Brian... there's no place close to your job? You have to drive THAT FAR to get to work? Please don't lecture me about trivialities like food content while you're commuting, taking vacations and road trips, and living miles upon miles from your place of work. I live close to my job. I don't take vacations, ever. They're a waste of money, time and energy. I live simple. Even today my idea of luxury is a book. I may drive thirty miles in one direction and visit friends. I don't go off on ski trips, road trips, visiting far away places, and so on. I eat very little meat. I have a garden (Do you have a garden?). Quote:
If anything Corporations love Environmentalism. Keeps their competition down, where it belongs. Now small business, that's another story. I worked for several small firms. To those guys it's the Bottom Line. How else do you grow big if you're not paying attention to things? Quote:
...except all of those kids who died in Africa from Malaria because of the DDT ban. Why sweat over thirty million dead people? They weren't white and malaria is a "natural population control", right? Yeah, I like to bring that up from time to time. Three times more people than were killed in Nazi death camps, silently, one mosquito bite at a time. They were probably too poor to buy their kid a coffin, just put him or her into the ground. Maybe they were even well nourished enough to shed a few tears. Thank God for white flour, refined sugar, cheap rice, heirloom beans, black eyed peas, and just a touch of DDT to keep the mosquitoes at bay. Gene Last edited by GeneW; 02-23-2009 at 11:26 PM. |
#12 | |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
oh, and the FDA? bought off? neeeeever. Lester Mills Crawford (born March 13, 1938) is a former Commissioner of the United States Food and Drug Administration (FDA). Dr. Crawford resigned from the FDA in September, 2005, two months after his approval by the United States Senate. On October 17, 2006, he pleaded guilty to conflict of interest and false reporting of information about stocks he owned in food, beverage and medical device companies he was in charge of regulating."[1] He received a sentence of three years of supervised probation and a fine of about $90,000 http://en.wikipedia.org/wiki/Lester_Crawford |
I don't like cola, none of it.
Give me a nice bottle of Jones Soda. I like the Green Apple and Bubble Gum flavors. And for my rum, . . . something citrus.
- The Black Ship Yaris - |
#14 |
§†ęĄ¶‡Ћ-NCP96
why would you wanna drink stuff that taste like bubble gum ?? :(
#15 |
Why would someone else want to drink stuff that is cola flavored ?
#16 |
I LOVE my Yaris!
Drives: 2007 Polar White LB Join Date: Oct 2008
I remember my grandpa brushing Coke on corroded battery contacts on his cars with a paint brush. It would eat the corrosion away....
We don't see things as THEY are...we see them as WE are. Lisa aka SIPNGAS |
#17 |
#18 |
it's the citric acid contained in those drinks.
| Soda Poll | Kaotic Lazagna | Off-topic / Other Cars / Everything else Discussions | 57 | 07-17-2007 03:31 PM |
