![]() Drives: meteorite liftback Join Date: Jun 2006
MAINTENANCE REQUIRED!!!
Hey guys i got in my car today and the maintenance required light flashed about 10 times when i started up my car. I'm just wondering if something is wrong or if it's time for the first oil change. The odometer is a lil over 4500. I changed the oil at 3000 but i know toyota recommends every 5000. Is this just a reminder for the 5000 mile oil change? Thanks.
YARIS LIFTBACK: meteorite metallic, 5speed, debadged, 15" black rota gt-3's w/ 205/50/15's, tanabe df210's, colibri universal power window kit, glow shift 2" tach and twm shortshifter. FUTURE MOD's: power door lock kit w/ keyless entry and new audio. |
Five-Star General
look in your manual, there is a way to disable the light manually if you know that you dont need the oil change.
![]() JWU '09 Baking and Pastry
![]() ![]() ![]() Drives: 2k3 Cavalier & 2k2 Echo Join Date: Aug 2006
Did the Yaris have a light especially to recall engine regular maintenance? Cause in my 2002 Echo, there's only one light and it's a "Service Engine Soon" light (Check Engine). And flashing "check engine" light is indicating a cylinder misfire problem.
I have this problem on my Echo because I have a cracked ignition coil on cylinder #2. I had to replace it cause the Echo is out of warranty (105,000 KM now). But part cost only 50$ and I replace it myself in 5 minutes.
2003 Chevy Cavalier Ecotec - His car! 2002 Toyota Echo Sedan - Her car... FOR SALE! Last edited by SimmZ; 08-20-2006 at 07:30 PM. |
It starts flashing on startup at 4,500 miles to let you know an oil change is coming up. It stays on after 5,000 miles. I think it's a great feature.
To reset - with the odometer in "Trip A" mode turn the ignition off - hold down the trip odometer reset button and turn the key to the "on" position (not start) - keep the reset button depressed for at least 5 seconds - you'll see several little dashes counting down and disapearing then all zeros display indicating it is reset. You're done. (The manual says it's not in Canadian versions.) |
#5 | |
Yeap, also in European versions...Dammit!
Thanks a bunch violin!! thought something was wrong with my car.
Look on the back of your thick manuals guys... its the first "quick note" listed.
![]() ![]() ![]() ![]() Drives: 2007 Yaris S Join Date: May 2006
was flashing check engine light at me for a couple days now, and just tonite i was driving, and BAM, hit 5k miles, and maintnance req. light comes on :)
was afraid i was going to have to get out the manual, but no need now, thanks :) |
Races Little Red Wagons
Drives: red '07 Yaris liftback auto. Join Date: Sep 2006
Thanks Violin.
![]() ![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jul 2006
Sweet, mon frer!!!
I'm at 4630 right now. My car will not get its first oil change before 6000 miles. |
I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
at 12000 it start blinking again
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
Lean Wit It. Rock Wit It.
Drives: 2007 Yaris Sedan - 5 Speed Join Date: Aug 2006
hehe chris always gets frustrated when people dont read their owners manuals..
YARIS... enough said!
#13 | |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 11:57 PM |
