Old 08-24-2006, 07:28 AM   #1
wushumasterku
Drives: 06 White LE HB 5spd
rattles (front of steering wheel)
anyone get rattles while driving around the dash in front of the steering wheel?
it just started today and i can't figure out why
wushumasterku is offline   Reply With Quote
Old 11-20-2006, 12:51 AM   #2
TX_Yaris
Drives: '07 Yaris Sedan - Red
Mine Rattles TOO
I also have a rattle to the front and left of the steering wheel. It seems to be related to the el-cheepo plastic storage cubbie on the left side of the steering column. --MJThttp://www.yarisworld.com/forums/images/smilies/mad.gif
TX_Yaris is offline   Reply With Quote
Old 11-20-2006, 08:08 AM   #3
the_saint
50% borikén
the_saint's Avatar
Drives: 06 Mazda5, 90 240sx
remove the loose change from the cubby and/or glove box.
j/k...I couldn't resist.
'06+ Toyota bB
Garson - D.A.D. aero
Zuenglein Dolci wheels
the_saint is offline   Reply With Quote
Old 11-20-2006, 06:33 PM   #4
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
see if you can insulate the glove box at the edges and see if it stops. if it stops just use a little stick on foam. your going to get rattles... its an industrial standard today.
Toyotech is offline   Reply With Quote
Old 11-20-2006, 06:33 PM   #5
Toyotech
does it rattle near the windsheild or what?
Old 11-20-2006, 07:27 PM   #6
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
mine rattles near the windshield on the drivers and passengers side, just wait until you get more miles on it and the heat/cooling cycles work on it some more. That nice tight finish in el-cheapo plastic and clips is short lived.
mikeukrainetz is offline   Reply With Quote
Old 11-20-2006, 08:04 PM   #7
Toyotech
just push some foam down towards the cowl. most toyota/lexus models rattles there, some worse then others.
Old 11-20-2006, 07:47 PM   #8
tekmoe
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3
Send a message via AIM to tekmoe
turn the stereo up louder!
tekmoe is offline   Reply With Quote
Old 11-20-2006, 07:50 PM   #9
ChinoCharles
Drives: LB
Its just the Yaris shaking its "moneymaker," which is located behind the fuse box.
Old 11-20-2006, 08:29 PM   #10
Bretsuaz
Drives: Yaris sedan
I need to get mine in. There is a rattle between the speedometer and the windshield that is beginning to drive me crazy. I have tried to locate it with no luck. There is also an intermittent rattle coming from the passenger seatbelt anchor. For those that have taken theirs to the dealer, were they able to fix it?
Bretsuaz is offline   Reply With Quote
Old 11-20-2006, 09:41 PM   #11
Toyotech
depends on the area of the rattle, most of what we will do is use a toyota insulation kit, foaming certain area's and padding others.
Old 11-20-2006, 10:25 PM   #12
static808
Engineer/Artist/House-Dad
static808's Avatar
Drives: 2006 Toyota Sienna XLE
if the insulation kit doesnt work, are you then allowed to replace parts inside of the panels?? just curious since my sienna has a rattle in the drivers seatbelt area, has the insulation kit installed, and STILL rattles in cold weather conditions (early morning, late night driving). i've got a case number going with toyota corporate, and a case manager is supposed to call by tomorrow letting me know my next options (the vans been in 3 times already for this, and all attempts have failed). its a shame since we absolutely LOVE this van, aside from the fact that every now and then it sounds like a small geiger counter is going off behind my left ear...
--B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror
Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels
static808 is offline   Reply With Quote
Old 11-21-2006, 06:28 PM   #13
Toyotech
--B
there is nothing to replace behind it. on the sienna b-pillar you have 2 10mm bolts for the grab handle (most of the time they are the problem on sienna's for rattle problems near your b-pillar)...besides that you have the clip in panel. the seatbelt adjuster is slipped into the pillar panel and its plastic on plastic. the only metal is the top ancor on the adjustor that the seatbelt bolts into. the hum that comes from the b-pillar is sometimes fixed with felting the slide or i have used a very thick grease that comes with a tsb on 4runner sunroofs.
all cars rattle, my corolla does, my gm does, my fords have... how do you think the people feel with ferrari's 6 series bmw's and sl55 amgs that have rattles... all automakers have rattles.
Old 11-22-2006, 01:06 AM   #14
static808
static808's Avatar
i know that was off-topic (sienna discussion), but thanx for the information! it's really weird how this noise (more of a ticking sound than a rattle actually)only occurs during cold weather conditions and slightly during left-hand turns. i mean, the first time i took it in, the service manager said that the noise definitely does not belong in the vehicle, whether its a $33K van or a $12K yaris. if they cant fix it, i might negotiate for a repurchase, since the noise does become deafening while driving at night, meaning there may be a factory flaw in the overall build of the vehicle. i know, i know, its just a ticking sound. but if its soo small a problem, why cant they fix it?? its like toyota placed a small time bomb behind my left ear, and it's set to go whenever we drive during darkness...
--B
Old 11-21-2006, 06:14 AM   #15
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
There is a Technical Service Bulletin for 2003-2007 Toyota vehicles.
If a creak, tick, or rattle noise is heard at the top or bottom of the windshield, the source of the noise may be the two windshield stoppers bonded to the top of the windshield or the windshield retainers bonded to the lower edge of the windshield. This bulletin provides the recommended repair procedure to eliminate these types of noises from the windshield area.
Check with your dealer.
Old 11-21-2006, 06:23 PM   #16
Toyotech
this is not-so-fun fix, and many times does not fix the noise... possibly 5% of vehicles will use that recall for the same complaint.
Old 11-21-2006, 09:46 AM   #17
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
I don't know if anyone notice, but the bracket for the high mounted brake light that mounted on the liftgate is quite loose, and it is rattling like hell when you're running at certain speed. Tried fix it at the dealership, but not helping much, it's still loose.
GabL is offline   Reply With Quote
Old 11-21-2006, 11:03 AM   #18
mikeukrainetz
So thats probably whats rattling when my subs are going pretty good.... never thought to check that.
front seat room Bigdaddy727705 General Yaris / Vitz Discussion 9 10-30-2013 11:26 AM
Xa - Yaris steering wheel jcove Cosmetic Modifications (Exterior/Interior) 1 05-09-2006 08:04 PM
Yaris wheel sizes and XA (ist) wheel sizes Master General Yaris / Vitz Discussion 10 04-18-2006 11:38 AM
