Old 03-22-2009, 07:42 PM   #1
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
All I wanted to do...
...was take out my seats so I could lay down some sound deadening material. I was so looking forward to getting that done this weekend until I ran into the BOLT FROM HELL.
It's a passenger side seat bolt on the seat rail closest to the door. All of the other bolts came out just fine except for this mf'n one. I swear that feckin thing must be welded in. Ok - I've run into this before - there's lots of things I can try. Gotta rule out PB or any sort of loosening spray because I can't get to the threads... fair enough.
Lemme try a smaller sized socket. No go. Ok - I can dremel down the sides and make some nice flat surfaces to grab onto. Nope, try again. Hmm... maybe I can slot the thing and get it out with a large screwdriver bit - hell no the metal on the head is too soft and the bit just fucks up the slot. Vice grips? Ha! Try again.
Wait - they make all sorts of cool doo-dads designed to get out rounded off bolts! Off to the store I run and buy a bunch of these miracle workers...none of them work. Ok, now the head is so fucked up that it's useless.
Time to dremel off the flange so I can at least get the seat out of the fecking way and then I'll be able to drill that bitch out. So I run through about three cut-off wheels and I can't get enough of the head flange off to be able to lift the damned seat out. The working space is terrible, the fact that the bolt sits in a recess makes it nearly impossible to get a good angle on the fecking thing. I can't even get at the bolt from the backside to flaten the sides to fit a socket!!!
What kind of shit soft metal are these bolts made of anyway?!? Everything I try just shaves off more metal. Here I sit with a massively cut up bolt - two days wasted trying to get the fecking thing out and no closer to success than when I started. Ain't that a bitch. I think I need a torch to cut the fecking thing out, but that would probably just set the interior on fire.
If I haven't tried something that one of you knows works well then please let me know. I give up for today and probably for about a week until I can tackle it again. I'm fucking pissed!!!!
Thanks for letting me vent.
Old 03-22-2009, 07:52 PM   #2
ChinoCharles
Drives: LB
^^ Me too.
Lefty loosey dude!
Old 03-22-2009, 08:06 PM   #3
firebob
Drives: 09 yaris
Lefty loosey dude!
+1
Cut the bolt head into as many peaces as you can and then rip and chisel what is left of the bolt head out.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 03-22-2009, 08:09 PM   #4
ChinoCharles
Drives: LB
Honestly, I say leverage. Put a longer lever on that wrench.
Old 03-22-2009, 08:14 PM   #5
You said "socket" -- but aren't those starz bolts (or whatever they are called)? Are you using the appropriate socket to grab those? It's a special one.
Old 03-22-2009, 08:17 PM   #6
Altitude
Altitude's Avatar
This didn't happen because I was turning it the wrong way.
I think some factory worker was OD'd on roids when he was torquing that fucking bolt.
I tried cold chiseling that fucker too. It won't budge. Anywho, I plan to provide pics of the carnage once I get the bastard out. Stay tuned.
Edit - Cali - yes they require torx sockets and I have the right one - like I said the other bolts came out easy.
Old 03-23-2009, 11:32 AM   #7
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Impact hammer on the head (or what remains). Drill through the rest without contacting the threads.
Old 03-22-2009, 08:20 PM   #8
ChinoCharles
Drives: LB
I was only messin Altitude... I didn't think you were turning it the wrong way.
Jackhammer + Yaris + video camera = WIN!
Old 03-22-2009, 08:35 PM   #9
Altitude
Altitude's Avatar
It's cool - I'm not offended and I figured as much.
I'm gonna make that bolt my bitch - it's personal now.
Old 03-22-2009, 08:36 PM   #10
ChinoCharles
Drives: LB
Please tape this.
Old 03-22-2009, 10:14 PM   #11
Altitude
Altitude's Avatar
I know I said I was going to wait - but I couldn't go to sleep tonight knowing that bolt was out in the garage mocking me and I swear I heard it laughing when I was writing the first post. So.....
Victory is mine! I gave up trying to take off the flange and gave one of those 'Bolt-Out' tools one more shot. So I ground down the bolt head (what was left of it) and tried one more time. Now I don't know if it was all the cursing, the heat from the grinding or just that the bolt decided it had had enough of my tough love, but this time it came out easier than all those before it. Go figure.
Sorry I didn't get to video the whole ordeal. It was quite the light show with sparks flying and shit getting in my eyes (yes I was wearing safety glasses but they made my vision like looking through a fishbowl so I had to take them off.) Anyhow - I snapped some pics to document the epic struggle.
This is a picture of the type of bolt used to hold down the seats in a Yaris.
This is a picture of the Torx Socket used to remove them.
This is a picture of the tools I used to extract the BOLT FROM HELL. Most of them didn't help, but I was desperate.
This is a picture of the mess it made. I was was real careful not to mess up the seat rail at first. Then I just said fuck it, a little paint and it'll be good as new. Besides I even contemplated hacking off the foot of the rail and buying a new one... That little tool you see to the right of it is the one that did the trick. It's tapered inside and has some 'cutting teeth' to grip the head.
It's not easy working with a Dremel in such close quarters as shown here.
These are some things that got broken in the process. Just some plastic bits from the end cap of the seat rail and a piece of broken cut-off wheel from the Dremel - there's a few more pieces of those somewhere inside the Yaris - but at least they didn't end up in my eye.
Here's a pic of the offending bolt after I had my way with it. Take that bitch!
Oh, if anyone is interested in having their seats removed, I'd be glad to help.
Old 03-23-2009, 12:25 AM   #12
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
...no pics showing up.....
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 03-23-2009, 02:25 AM   #13
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Please fix pics...The suspense is killing me. It reminds me of the oil filter I had that I bent a pry bar in an attempt to remove.
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 03-23-2009, 02:33 AM   #14
tried to fix the pictures but the original attachments are no longer there?
Old 03-23-2009, 09:21 AM   #15
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
Maybe somebody put a couple drops of locktite on the the bolt after they cross-threaded it at the manufacturing plant.
Old 03-23-2009, 11:28 AM   #16
Shroomster
Shroomster's Avatar
pics are good now....
didja ever think to try some pb blaster or other lubricant at all during this ordeal....?
Old 03-23-2009, 11:46 AM   #17
Altitude
Altitude's Avatar
I mentioned that in the original post.
The thing just wouldn't budge and I ended up stripping the head so I could no longer grip it - hence the fiasco. If this had been a standard bolt with a flush surface and easy access it wouldn't have been nearly as difficult as it was. Once I got it out it didn't seem as though it was cross threaded or anything like that. I think I just was unfortunate to have a bad bolt. Maybe some impurities in the metal during casting because it stripped pretty easily and the others seemed to take the torque much better and showed no signs of weakness.
Old 03-24-2009, 12:24 AM   #18
Shroomster
Shroomster's Avatar
BLASPHEMY!!!!! <<lol
pb and the other lubes (wd-40, etc) actually will seep down to the threads...but whatever...
the deed has been done and you have been victorious....
Just wanted to thank everyone chibipod New YARIS Purchase Forum 16 01-01-2009 03:20 PM
Wanted To buy steel parts brooklynsual Asia 1 11-26-2008 11:23 AM
Who wanted Honda springs? cali yaris Australia 1 10-21-2008 07:56 PM
WANTED: 4 Wheel Covers galaxyhillvt Items for Sale by private party 2 07-11-2007 04:05 PM
WANTED: 3dr side skirts (SENT TO AUSTRALIA) ASHRAF Items for Sale by private party 4 07-11-2007 07:50 AM
