back lit control?
First night out with the car I noticed that the pod that holds the mirror switch, and cluster dimmer control is not back lit, nor is the controls on the driver side door IE: the door locks, window locks or the other window switches (the auto down is lit.) The passenger door switches aren't back lit either. Is this just mine sedan or aren't any of the sedans back lit? I also noticed the the radio controls and three knobs that control heat and air are also a quite a bit dimmer than the speedo cluster. If you dim the speedo cluster to a comfortable level then you can't see the display on the radio very well. I have the square faced radio with the buttons down each side.
Any input? |
Pixitha
I also noticed the issue with the radio back light being super dim, if i lower the HUD to a normal level....I found the HUD to be a bit too bright, but now the radio is a bit too dark!
2007 Yaris Sedan here |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
the thing I don't understand about the sedans is when you 'click' the dimmer switch all the way up it turns off the lighting....all the other toyotas actually use that 'click' to lock the displays to max brightness
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
#4 | |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
BTW.....My Sedan has back lighting behind the lock/unlock buttons..... |
So I'm going to take it that nobody has back lit controls...
To fix the radio being too dim, I suppose you could put a resistor in line with the HUD unit to dim it a bit further, and then turn the brightness up for the radio. It might take a little experimenting to get a good balance. |
![]() ![]() ![]() Drives: Black '09 2dr HB Join Date: Feb 2009
Yea the only stuff I have lit is the middle stuff, not the locks, window, & dimmer control.
But my old car didn't either so it didn't even occur to me to be bothered that its not lit. |
ya, the only thing that is lit on mine is 'auto down' window button...
| Digital Gauges, Auto Climate control, Manu-matic shifter | computerlove87 | Cosmetic Modifications (Exterior/Interior) | 21 | 12-02-2012 11:55 PM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Back hurt? | yarswiss | Off-topic / Other Cars / Everything else Discussions | 10 | 11-14-2008 04:39 PM |
| Rear wiper: EZ mod so it pulls back all the way | joelitton | Cosmetic Modifications (Exterior/Interior) | 10 | 10-22-2008 10:30 AM |
| HELP!!! I went back to the service center yesterday for the 7th time in 2 months! | Meldav86 | General Yaris / Vitz Discussion | 27 | 08-21-2007 09:04 PM |
