Old 04-08-2009, 08:26 PM   #1
ztlonewolf
ztlonewolf's Avatar
Drives: 2008 red 3 dr S coupe
Unhappy Tire pressure sensors
Ok,i get in the car this mornig to go to work,after i start it,the tire pressure sensor light is on,so i think that i have a low tire,after work,i check the pressure in all my tires,found the air pressure was low in the spare,filled it up to 60 but the light won't go out,all the other tires were properly inflated,do i have a bad sensor or do i have to reset it somehow?
ztlonewolf is offline   Reply With Quote
Old 04-08-2009, 08:41 PM   #2
firebob
Drives: 09 yaris
Is that PSI? I think 60 PSI twice as much air as you should have in a spare tire. My dads 10 ply tires have a max of 50 PSI and a donut should be 2 or 3 ply.
I did some searches and did not come up with the specks for the OEM sensors. But you could have a low battery in one tire.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
Last edited by firebob; 04-08-2009 at 08:51 PM. Reason: added info but not worth a new post
firebob is offline   Reply With Quote
Old 04-08-2009, 10:25 PM   #3
ztlonewolf
ztlonewolf's Avatar
ya,that's 60 psi,that's according to the spec's listed on the tire itself and also in the owners manual.
Old 04-08-2009, 10:22 PM   #4
The Yaris TPWS doesn't monitor the spare - It just looks at the 4 mounted tires.
Check out this post for a method of finding out what the error is without having to go to the dealer:
http://www.yarisworld.com/forums/sho...8&postcount=11
Old 04-08-2009, 10:43 PM   #5
uncleyaris
More options more goes wrong I think.
Old 04-13-2009, 12:47 PM   #6
b_hickman11
Drives: 08 Sedan
Its not an option....
Old 04-13-2009, 12:54 PM   #7
SailDesign
Drives: .
sadly...
Old 04-24-2009, 12:43 PM   #8
b_hickman11
Drives: 08 Sedan
sadly...
thats your Gov't at it's best!
Old 04-25-2009, 05:19 PM   #9
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
And that's sad.
Old 04-09-2009, 09:54 AM   #10
firebob
Drives: 09 yaris
I would have never thought a donut would be 60 psi.
Old 04-09-2009, 10:55 AM   #11
Yaris Hilton
Smile
Yep, it's true.
Old 04-09-2009, 11:37 AM   #12
WolfWings
WolfWings's Avatar
Compact spares are basically always ultra-high-pressure tires, 60psi is almost a standard. I've had some cars that uses as much as 75psi or 80psi in the spare.
Old 04-09-2009, 09:25 PM   #13
ztlonewolf
ztlonewolf's Avatar
well,for some odd reason,it went off tonight,it was on when i came home from work,but when i went back out to the store,it was off,so hard to tell what was wrong
Old 04-09-2009, 09:39 PM   #14
The TPWS keeps its trouble codes until they are cleared with the Techstream tool, so even if the light is now off, you should still be able to find out what the issue is using the procedure above that I posted the link to.
Old 04-09-2009, 10:52 PM   #15
Ed_
Drives: 09 2 dr, 5M, Yellow
700 cc bicycle tires carry over 110psi.
Ed_ is offline   Reply With Quote
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 10:17 AM
Tire Pressure Monitor Sensors....? 09TRD Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-19-2008 09:25 PM
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 05:53 PM
2008 Yaris with Tire Pressure Sensors nsmitchell General Yaris / Vitz Discussion 2 08-23-2007 11:34 AM
