![]() Drives: 86 GTS Join Date: Apr 2009
How do you remove front lip?
I tried searching but came up with nothing. I want to replace the oem front lip on my 4 door Yaris S but I dont know how to remove it. I took off the 2 screws on each side and the 4 bolts underneath but the thing just wont come off. What am I missing? I dont have a jack at the new place I moved to so its hard since its far away from home so its making things tough to look underneath.
![]() ![]() ![]() ![]() Drives: Yaris YR Join Date: Oct 2008
Pretty sure there's at least some sort of tape or adhesive glue used. So it won't just come off once the screws are off.
My side skirts i just got done recently are bolted on and glued on. You might have to heat up the sides abit with a hairdryer or heatgun im guessing. Im not 100% on that so you might want to wait till someone else chimes in.
![]() Mods: 17x7 ANZ Tazer Wheels with 215/40/17 Marangoni Tyres | AFE Air Intake System | NST Short Shifter Kit | NST Shifter Cable Bushing Kit | NST 10% Underdrive Crank Pulley | Pedders Sports Springs | Custom 2inch Cat-Back Walker Muffler with 2.5inch Xforce Twin Stainless Steel Tip | RS Side Skirts | RS Euro Spoiler | YRX Front Lip Spoiler | TRD Style Front Grill | 12mm Rear Hub Spacers | Ultra Racing 23mm Rear Sway Bar |
It might have at one time but I dont think that it is anymore or maybe not the whole lip anymore. Like I can move it somewhat but not the whole thing. Like I can bend the sides but not so much in the middle.
Look around the lip. Do you see a black rubber-looking thing? If so, I think that's the adhesive (in addition to the bolts/screws).
there are at least 4 clips behind the lip. I simply yanked it out whatever was holding in the middle.
the little rubber band do adhere a little, but that's just a little. When the lip is out, you are left with a bunch of holes on the lower bumper :P |
![]() Drives: RS Join Date: Apr 2010
Can someone tell me where to get the rubbers in between the panels and the moldings, once you un-glue the aero package?
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Maybe the dealer... although I have a feeling they will tell you you have to buy the entire moulding.
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
| My new vios grill and front lip splitter Pics Inside =) | YarisSedan | Cosmetic Modifications (Exterior/Interior) | 10 | 02-21-2009 12:51 AM |
| 2009 Sedan Aerokit Front Lip Part #? | Split | Cosmetic Modifications (Exterior/Interior) | 9 | 11-26-2008 07:19 PM |
| How hard is it to remove side skirts and front lip on 08 sports package? | dono37 | Cosmetic Modifications (Exterior/Interior) | 15 | 09-26-2007 05:28 PM |
| Front Lip on S has peeling paint... | fnkngrv | DIY / Maintenance / Service | 7 | 09-05-2006 03:32 PM |
