Old 03-12-2006, 05:06 AM   #1
Kenbow
Vitzliste Page Master
Kenbow's Avatar
Drives: Vitz 1.5X Kai & ARISTO 300
Exclamation Vitz&Yaris Custom Information
What kind of customization is everybody doing?
My Vitz be such a feeling
I want to try to see even the car of everybody
Also, being attached to my Vitz I answer it if there is a question
Front spoiler be GIALLA
Side spoiler be GIALLA
Back bumper be RS swap
Wheel 18inch 7.5J  205/40-18
Vitzliste Web Page Master Kenbow
http://www.k4.dion.ne.jp/~vitz/
Kenbow is offline   Reply With Quote
Old 03-12-2006, 05:30 AM   #2
echo_hrs
Around the universe...
Drives: Uber-Evolved Pokemon
Mine is the Yaris RS grade for Canada, with lowering springs...
I'm planning to either import a factory front spoiler from Australia, or the JDM Vitz RS front bumper...
Cheers
echo_hrs is offline   Reply With Quote
Old 03-12-2006, 07:05 AM   #3
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
kenbow-
what offset are your wheels?
what is the widest wheel and lowest offset do you know other yaris/vitz owners do? :)
Master is offline   Reply With Quote
Old 03-12-2006, 12:32 PM   #4
Kenbow
Kenbow's Avatar
Originally Posted by Master
kenbow-
Master-
The offset is F:+42 R:+37.
It is necessary to note it for the installation.
The reception desk comes in contact with the inner liner when the steering wheel is turned.
However, contact can be avoided by warming and processing the inner liner.
Rear comes in contact with the fender by the individual difference of the vehicle.
Because only the right side came in contact, my vehicle processes the fender a little.
The widest wheel in the data that I have is 18inch 9.0J 215/40-18 offset F&R+48.
A lot of problems seem not to be functional though there is putting 19inch in Vitzliste Member.
Old 03-12-2006, 02:36 PM   #5
yariman
Speed Wrenchin'
yariman's Avatar
Drives: 2006 Yaris 3 door, Bayou Blue
The 18's look awesome, but they are 2 inches in diameter bigger than stock. This is like installing higher gears in the diff. which robs performance. If you wonder why she doesn't fell as peppy any more, that's why. But hey, it is hard to beat the look.
Quench my thirst with gasoline
yariman is offline   Reply With Quote
Old 03-12-2006, 02:48 PM   #6
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
^^ you are keeping the same drive ratio if you get the correct height on tires. He is running a "40" profile tire to offset the increased wheel size
Old 03-12-2006, 04:39 PM   #7
LAHAL
LAHAL's Avatar
Drives: 07 Yaris RS B package Manuel
dealership told me that if you keep the same height on the wheel, then it won't void the warrenty, it only void if your wheel is larger then the stock wheel. I was going to go with 18, but we have to many pot holes in calgary, i'm gonna stick with some 17 so not to sacrifice on the tire.
LAHAL is offline   Reply With Quote
Old 03-12-2006, 05:38 PM   #8
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
i've never heard of a dealership voiding warrenty cause of wheel size
Old 03-12-2006, 07:32 PM   #9
yariman
Speed Wrenchin'
yariman's Avatar
Find a tire size calculator on the net, put in your stock size and an 18" size with a 40 profile and see the difference.
Old 03-13-2006, 12:15 PM   #10
Kenbow
Kenbow's Avatar
The same size tire is different the absolute size because of the manufacturer.
The tire computer is not reliable.
The tire is pulled to 7.5J a little in my size of the wheel though it grows by one inch on the calculation because the tire of 205.
Is the pull of the tire understood?
For instance, the case where 205/50-15 tires are installed in the wheel of 15 inch 8J is said. (An extreme size is shown for the explanation. )
Old 03-13-2006, 12:43 PM   #11
yariman
Speed Wrenchin'
yariman's Avatar
Kenbow, do you still have your stock tires/wheels? If so put them beside your 18's and see if there is a difference.
Old 03-13-2006, 10:26 PM   #12
Kenbow
Kenbow's Avatar
I understand what you are saying
What I wanted to say is that there is an error a little by the tire maker
My English is pitiable and excuse me
I think that I am good if you choose the tire and run favorite Wheel early
Old 03-12-2006, 08:49 PM   #13
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
kenbow is running a 205 tire on a 7.5 width wheel.
think about how much that tire is stretching on that wheel and why the 40 profile is needed.
Old 03-12-2006, 09:44 PM   #14
yariman
Speed Wrenchin'
yariman's Avatar
Sorry, I thought he had 215's. The stock 175/65/14 is 23 inches in diameter, the 205/40/18 is 24 inches, an inch bigger in diameter, still slows you down. Some folks are looking for the lightest wheels possible, but if the diameter is larger, buddy beside you in the Yaris with smaller wheels is going to win!
Old 03-13-2006, 07:37 AM   #15
jcove
jcove's Avatar
Drives: 2011 Rogue
In theory that is right, but if the wheels are lighter than stock then you have less unsprung weight and you keep or better the acceleration. I'm interested to know if you'd even feel the difference.
jcove is offline   Reply With Quote
Old 03-12-2006, 10:08 PM   #16
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
haha i'm not planning to race my yaris when i get it.
it's going to be a cruiser car. i think most ppl in japan are the same way.
i want 18's with the biggest fattest dish i can get in the back ;)
Old 03-12-2006, 11:48 PM   #17
Kenbow
Kenbow's Avatar
It is because the reason that I chose 18inch 205/40-18 is appearance esteem
In the case that I choose a functional thing 17inch 205/40-17 Best Match
Because Compressor of BLITZ is fixed at the later time outside diameter is not a problem
If even the offset thinks 215/35-18 are Best to 18inch
I do not exist that I felt inconvenience by making 18inch
This time, I challenge it to 19 inches
You consult the following HP in the case that the Wheel information of the 18inch following wants
http://www.k4.dion.ne.jp/~vitz/EnglishInchup.htm
Old 03-13-2006, 12:05 AM   #18
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
that's right kenbow!
STYLE is always king ;)
is your car supercharged?
19 inch wheels on a yaris would make the wheels look huge!
custom speaker in the deck box? twixt In Car Entertainment + Electronics (audio / video / alarm) 12 04-06-2006 08:40 AM
