Old 05-06-2009, 01:42 AM   #1
codymclelland
Startin small.
Intake HP Increases
So I've been lookin around here and on some vendor sites (Mostly Micro Image) for intakes. First off, is an AFE or AEM better? Secondly, what is the approximate increase in HP and MPG (if applicable) for each type?
codymclelland is offline   Reply With Quote
Old 05-06-2009, 02:00 AM   #2
Well, the AFE would require less work to clean the filter since the filter sits in the engine bay, whereas the AEM goes down behind the foglight, and to clean it would require removal of the front bumper, or removal of the front wheel and fender liner to access the filter. Both are essentially CAI (the AFE has a heat shield, and the AEM is a true CAI). HP gains by itself will probably be negligible, and FE will be affected depending on how you drive. If you drive lightly, it should increase your mpg (I know it did on my GTI), but if you push harder to hear it suck in air, then you'll eat up more gas.
Old 05-06-2009, 02:09 AM   #3
codymclelland
Startin small.
So the TRD site says their CAI would increase about 11.2 at 6000+ rpm... is that actually negligible? I'm looking to boost some HP a bit while making sure that any increase in sound is as throaty as possible so as to be distinguishable from a ricer with stupid fart pipes. Actually, on the subject of exhaust... what's the best way to go with that? Do I need headers, or a midrange (as I know the Yaris' is restricted), or is it just a rear piece/muffler. I've never even looked at my exhaust to be honest! But I like the nice throaty sound with some HP increase. Advice?
Old 05-06-2009, 02:28 AM   #4
LOL. I don't think they're telling the truth. That's almost a 10% increase in power. Shoot, a supercharger "only" nets an extra 50 hp (that's a lot for our car actually). I can't remember the numbers, but I think ~11 hp is what Garm got with headers, exhaust, and intake (may be some pulleys too).
As for the exhaust, go with custom cat-back. It'll be cheaper. Go with either Magnaflow or Flowmaster if you want a throaty sound. I have a Magna on my sedan, and I had a Flowmaster on my GTI.
Old 05-06-2009, 03:49 AM   #5
No intake is going to net you 10 hp, I don't care what the claims are. But, every little bit helps with our cars and they do add up.
I prefer the AFE right now, it's easier to take care of, makes the same amount of power (in my opinion), costs less and sounds great.
Old 05-06-2009, 04:03 AM   #6
Also, the AFE is aesthetically more pleasing imo since it doesn't leave a huge gap in the engine bay. hehehe. But that's just me.
Old 05-06-2009, 04:28 AM   #7
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
+1 on the AFE intake , got one and love it ,if you get one
you won't regret it
Old 05-06-2009, 06:58 PM   #8
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I like the gap so that I can cram in the oil catch can. I took the metal heat shield off the aFe setup to make more room. Pictures this weekend.
Old 05-06-2009, 07:00 PM   #9
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
I took the metal box off the AEM setup to make more room.
you mean the afe?
Old 05-06-2009, 08:25 AM   #10
severous01
once i finally installed mine properly i had no problems with my afe. i got about 3 mpg out of it and if anything i driver harder than i used to....but i get to speed and stay there.
any way, it comes with 2 really thick nylon washers....ur supposed to put those in the rubber holes for factory box and then put some bolts through into the heat shield. when locked down it doesnt rattle like it used to at all. that's the only prob i had.
Old 05-06-2009, 08:45 AM   #11
ebay ftw
Old 05-06-2009, 09:23 AM   #12
33OH
Drives: '08 Yaris
http://shop.microimageonline.com/pro...2&productId=74
Old 05-06-2009, 10:00 AM   #13
mastaofdisasta
mastaofdisasta's Avatar
Drives: yaris
AEM ftw. Just to be diffrent.
btw the TRD intake is an AEM intake, just has a TRD badge on it.
ballin on a budget.
mastaofdisasta is offline   Reply With Quote
Old 05-06-2009, 12:13 PM   #14
Astroman
Modded Moderator
Astroman's Avatar
I love my AEM, and with my foglight cover mod it reduced the intake temperature by 10 degrees.
Old 05-06-2009, 10:34 PM   #15
kurokoma-kun
Drives: 2007 Yaris HB
I also have the AEM, works great, love the sound it makes
Ah, Astroman! I coulda sworn someone did this but could not remember who or find a pic! I just sold my foglights and will be making the same type vent soon--did you back yours with any kind of mesh? did you use a dremel or utility knife?
Old 05-06-2009, 01:06 PM   #16
ooh, we need a carbon fiber version of that.
Old 05-06-2009, 06:46 PM   #17
codymclelland
Startin small.
Yeah I definitely didn't believe the claim of "up to 11 HP increase"... just a bit of BS... Where's the best place to get the Magnaflow? Also, with the exhaust, do you need to get headers? Or just the tail end? Again, haha I don't know how the whole exhaust goes together.
Old 05-06-2009, 06:53 PM   #18
codymclelland
Startin small.
Oh and another question about the intakes. With the CAI, is the temperature decrease negligible because of the distance of the tubing that the engine could warm the intake pipe which would then make the difference about the same as the short ram? I saw one thread where the owner wrapped the CAI tube in insulating tape and he said it helped. Sorry for all the questions! I'm just really torn between the two! Also, with the CAI, is there really that much of an increase of danger for hydrolock?
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
MY new PRM Intake... marcus Performance Modifications 27 05-04-2009 12:04 AM
Bomz Ebay Intake - Partial Review Split Performance Modifications 11 11-19-2008 03:12 AM
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 04:00 PM
