![]() ![]() ![]() Drives: ings 09 Yaris 3 Door LiftBack Join Date: Mar 2009
DIY: NST SSK in MY09 LB
I just installed the NST SSK in MY09 LB with little modification. Pic showed that the shaved part of it to make it fit on my LB. Ppl are saying that some 09 Yaris might have different shift linkage than 07-08, I guess I might have the different one because I was following the other install thread and noticed it right away that it wouldn't sit right on top of it like the other one, something was in the way, I couldn't see the pin hole. If you compare the sliver plate(under the SSK) near the round rubber cap, it actually looks a bit bigger than the other one on the other SSK DIY thread, so shaving it a bit is a MUST!!
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… Last edited by AlainMikli; 05-06-2009 at 06:16 AM. |
![]() Drives: yaris Join Date: Aug 2009
can u post pictures of your car ?
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Did you remove the air box for this DIY?
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
yes, you can see from the last pic that there is no air box.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
Show & Go
Nice DIY
| NST (NonStopTuning) Short Shift Kit Info, Specs, User Data... | NonStopTuning | Performance Modifications | 195 | 12-23-2011 12:44 AM |
| NST SSK & New Wheels here :D | Arkhangel | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-25-2009 07:42 PM |
| Question About NST SSK | Arkhangel | Performance Modifications | 4 | 10-24-2008 11:55 PM |
| NST ssk | OxyG3nE | Items for Sale by private party | 6 | 10-24-2008 06:22 PM |
| DIY - NST SSK (short shift kit) | kurokoma-kun | DIY / Maintenance / Service | 0 | 10-20-2008 01:12 PM |
