Car Geek
Drives: Yaris Liftback Join Date: Apr 2006
SRS warning light - any guesses?
My new Yaris is telling me that something isn't right. After about a month of ownership, the airbag warning light is now lighting up. The car is totally stock.
I did notice a little rattle in the B-pillar a while ago - I wonder if somebody at the factory might not have fully connected a wiring harness (pre-tensioner?) and it's worked loose. I'll mention my little theory when I take it in. Does anybody know if the Toyota scanner shows different codes for SRS warning situations? Any guesses as to what's wrong?
Kevin '07 Blazing Blue 5-speed liftback (sold) '08 Black auto liftback (sold) '09 Carmine Red auto 4-door liftback (sold) |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
under warranty.... take it back to the dealership..... since it is a fault in the safety devise you will get a rental if it can not be fixed that day......
do not fiddle with it, may give them a reason to not cover it under warranty
Car Geek
Agreed. I didn't think about the loaner situation; sounds like a good opportunity for an extended test drive.
Car Geek
Just updating/finishing the thread after getting my car back.
Dealer noted that the system lost contact with a portion of the circuit (didn't specify what part). Lost communication described in service notes as "side satellite sensor bus". Trouble code "B1642" was in the history, per service notes. Just in case this info is useful to somebody...
Car Geek
Another update...
SRS light came on again today. In case anybody has one of these airbag warning lights come on, the specific error code is erased if you turn off the engine. The car's computer will store a general code in its memory, but the general code doesn't give specific info about the fault.
Even with the light on, the engine running and the diagnostic machine plugged in, though, the dealer is still can't find the fault... Aren't electrical problems fun?
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
lol sounds like an intermittent wire problem .....gonna have to do a trace.....
Car Geek
This is getting to be a pain...
The SRS light keeps lighting up. I've been back to the dealer twice for this problem, and the light has lit up again. I must admit that my dealer said that it probably would since they couldn't isolate the problem the last time. Unfortunately, I didn't get any paperwork from the last visit; if this continues I'm going to start getting cranky with Toyota (ie three visits = lemon). Although a light on the dash isn't a big deal, my dealer tells me that the SRS system won't deploy when it's lit - that is a big deal.
Coincidentally, my Toyota "how do you like your car" survey showed up in my email. This could be fun...
Car Geek
Still a pain...
Took the Yaris in today (third time). In order to fix the problem the conclusion was to replace the entire central wiring loom. Unfortunately, there aren't any central looms available in North America. My car is currently sitting at the dealer with its guts hanging out and I'm driving a Corolla loaner.
This is like when I had my first Yaris - the entire tranny needed to be replaced for an oil leak. Toyota wound up air-lifting a replacement from Japan to expedite the repair. Based on this experience, I don't think Toyota will take that long to produce the new wiring loom. Here's a link to an old thread on my tranny service experience: http://www.yarisworld.com/forums/showthread.php?t=1961 Just sharing yet another unique Yaris service experience.
Car Geek
Well, it's been two weeks and my car might be ready by the end of the day. The Corolla is a nice car, but I've missed my little Yaris. Just for giggles, I took a few pics of the Yaris "on the operating table". Glad I didn't have to pay for this:
lemon law that beast ASAP
Car Geek
I appreciate the idea, but I'm confident that the repair will be fine. If this replacement somehow doesn't solve the problem, though, I'm sure my dealer will offer to set me up with another car.
I'm interested to see if this process introduces rattles into my interior. EDIT: No need for Dynamat with me; I'm happy with how the interior sounds (don't want to add weight, either). Thanks for the suggestion.
#12 | |
![]() ![]() ![]() ![]() Join Date: Feb 2010
Well I thought it was a good idea...I sometimes wish my Yaris did weigh a little more. Now if it was a boat or plane that would be a different story. |
With the seat and carpet out, you should have them throw down some dynamat before they put it back together.
#14 |
![]() Drives: 2007 Toyota Yaris Join Date: Mar 2014
My SRS light came on today. I called the dealership and they told me they would have to run a diagnostic test to see what the problem is. If they find the problem and it gets approved for repair under my warranty (I have 100,000 mile Platinum certied pre-owned) they will fix it for free. If the repair is not approved it will cost me 140$ for the diagnostic. Does this sound right? I was thinking about getting the diagnostic check done on my own and calling corporate to see if it will be approved. When asking the guy at the dealership if "airbags" were covered under the warranty he couldn't tell me yes or no, will I run into the same brick wall if I call corporate myself. It seems if I have the problem identified they should be able to tell me. Any thoughts on how to best approach this situation?
#15 | |
http://www.yarisworld.com/forums/sho...d=1#post557473
#16 |
thanks man, I appreciate the reply. wish me luck
| DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) | CTScott | DIY / Maintenance / Service | 221 | 07-16-2025 01:20 AM |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| srs / airbag light after head unit install? | KwonSau | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-24-2008 02:04 AM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
