Old 05-26-2009, 12:29 AM   #1
Astroman
Modded Moderator
Astroman's Avatar
HELP! Removing manual window crank
Searched, and tried, but I can't get the stupid window crank off. I know there is a metal clip in there, and heard something about a "rag" trick. Putting tint on my girlfriends windows and although I was able to get the door panel off enough to get the tint on, getting the door panel back on with the crank still on there is posing a problem. Any help would be appreciated, especially if you can post pics.
Thanks!!
Old 05-26-2009, 12:53 AM   #2
evil genius
Drives: 09 Yaris S 3dr
Slide rag between crank base and door panel, then move rag side to side. The clip should pop off, then you can pull the handle off.
evil genius is offline   Reply With Quote
Old 05-26-2009, 12:24 PM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Bend the end of a wire like a large paper clip into a hook. Push down on the door panel opposite the crank handle. You should see the clip. Hook the clip and pull it out.
Old 05-26-2009, 04:37 PM   #4
Astroman
Modded Moderator
Astroman's Avatar
Can't wait to go and try these tips. Going to finish the tint on the '09 and hopefully get started on the '07 today.
Old 05-26-2009, 05:02 PM   #5
Popped mine off many times with the cloth trick. Got pics somewhere that I took but never posted for a speaker DIY.
Old 05-26-2009, 05:04 PM   #6
Astroman
Modded Moderator
Astroman's Avatar
I think my problem last night was the rag was too thick. I'll find an old t-shirt, that should work better. I'm used to the old cars that just had a cap on the crank, and a simple screw holding it on there.
Old 05-26-2009, 05:06 PM   #7
I had an old supply of baby wash cloths around which happened to work perfectly. I hear ya about the old cap and screw.
Old 05-26-2009, 06:03 PM   #8
Pics
Old 05-26-2009, 08:46 PM   #9
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
they sell little metal tools that do the same if you're somebody that does this often... I still have mine... cost like $7 back in 2001 and I've used it probably 15 times.
Rear Window Removal idipudipwedip2 DIY / Maintenance / Service 1 03-27-2009 05:09 AM
C54 MANUAL TRANSAXLE service manual needed ricepower DIY / Maintenance / Service 1 08-29-2007 07:24 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
The Toyota Authorized Repair Manual. LoudYar General Yaris / Vitz Discussion 3 03-29-2007 12:20 AM
window crank KSIbucky DIY / Maintenance / Service 3 10-19-2006 12:01 AM
