![]() Drives: _ Join Date: May 2009
___
___
rice rocket
Drives: 05 Echo Join Date: Feb 2007
It should be possible to wire both together, but you'd probably want to run a switch that can swap the audio signals. Not sure if you want two audio sources fighting over the amps.
You will need a separate 4 channel amplifier to power the car's stock speakers. You will want to invest in a good carpc power supply which will monitor ignition status and automatically control startup/shutdown (and handle any voltage spikes which could harm your hardware). Since this thing uses a DC power supply, dependent on the voltage you could get a power regulator that can supply that voltage (carnetix has a few voltage regulated power supplies) instead of figuring out how to rewire an M2-ATX power supply.
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
| Not sure where to start (2009 yaris)... | Faith87 | General Yaris / Vitz Discussion | 37 | 03-23-2009 05:35 PM |
| thewifesyaris - photo scavenger hunt | thewifesyaris | Photo-Video-Media Gallery | 0 | 03-01-2009 06:02 PM |
