Old 03-20-2006, 10:13 PM   #1
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
Why is the liftback heavier than the sedan?
...not by much, but it's heavier. I would assume it would be lighter since it's actually smaller. All the hatchback hardware? Bummer.
http://www.toyota.com/yaris/specs.html
Idjiit is offline   Reply With Quote
Old 03-20-2006, 10:31 PM   #2
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
you're weird...it's TWO...count em ONE TWO fucking pounds heavier.
you should work harder on getting a return on taxes or some shit
Master is offline   Reply With Quote
Old 03-21-2006, 08:38 AM   #3
Idjiit
5 Stars, Bitches
Yeah, but intuitively I'd expect it to be maybe two hundred pounds lighter since it's missing two doors and is 16 inches shorter.
Old 03-21-2006, 09:13 AM   #4
echo_hrs
Around the universe...
Drives: Uber-Evolved Pokemon
Because it is more compact, The hatchback needs more reinforcement in the suspension/bumpers etc, to meet crash specs, which adds weight.
echo_hrs is offline   Reply With Quote
Old 03-21-2006, 09:38 AM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Indeed. Odds are that it will also be more rigid, which means it will be easier to get it to handle better.
Old 03-22-2006, 09:47 AM   #6
why?
why?'s Avatar
Drives: Yaris LB
The hatch is heavier, yet it is shorter by 16 inches. This means that the chassis is stiffer, which by itself will mean better handling.
A longer wheelbase does not equate to better handling. They make the wheelbase longer because the ride will be better. Shorter cars in general handle better.
There is no way to tell weight distrubution without putting the car onto a scale that measures the weight at each corner.
Both cars stock will prolly handle very similar. I just believe it will be easier to make the hatch handle better, in other terms, I believe aftermarket parts will be more effective on the hatch.
Old 03-22-2006, 10:51 AM   #7
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
Drives: 2008 Mazda3 S Sport
FWD are almost always front heavy anyways
Code:
DiabolicJourney_SpaRky
DJ_SpaRky is offline   Reply With Quote
Liftback or Sedan? 118traut General Yaris / Vitz Discussion 17 02-06-2006 07:45 PM
