![]() Drives: Yaris Join Date: Jun 2009
folks,
Hope someone can help... went to jump start my 2000 Yaris and didnt realise i had the lead on the wrong battery poles (idiot!) ...reverse polarisation i believe its called ...there was a few sparks with car starting up then it died and no electrics are working at all!! Im hoping i've just blown fuses? or have i done something much worse?? I replaced 2 of the small sized fues (15 amp) in fuse box beside the battery that i could see had blown but that hasnt made a difference. Would i have blown the main fuse and where is this located? Any help really appreciated, feel silly enough for doing this + cant afford to be spending big money fixing it. |
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
Looking at the owners manual (p263) it looks as though there is a fuse on the actual power wire off the battery. I'd check that first. Then the other two fuse boxes. Make sure you don't see any burnt wires anywhere. I would say check the voltage on the battery, but since you had to jump it I guess that would mean its already dead lol. Hopefully you didn't fry the computer. That sounds like an expensive fix.
http://www.etimago.com/yaris/repairmanual/
#3 | |
Yeah really hope i havent fried the computer! reading one too many horror stories online ...has me panicking!! I'll try that fuse on the power wire, didnt notice it earlier. thanks for your help. I'll let you know how that goes. |
#4 | |
Cheers for your reply, i'll pick up a voltmeter later and try it. I should get about 10 volts across the terminals yes? Fact that i was getting absolutely nothing when i turned the ignition had me thinking it wasnt the battery, i wasnt even getting warning lights or engine trying to kick in. nothing. any other suggestions i should also try? thanks. |
#5 | |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
Many cars now have reverse polarity protection, but looking at the EWDs, the Yaris definitely does not. If you are lucky the 60A main fusible link popped and possibly the 120A Alternator one as well (on that same block).
#7 | ||
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
not trying to be rude, but to be perfectly honest, i am 80% sure that you ECU is fried as you don't even get warning lights(my suggestion in this case, check ebay or your local wrecking yard)... for battery voltage on a goo d battery, you should be getting 12.6 volts... however, just for the sake of argument, that fusible link is a good idea to check...
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
I gotta believe you popped a fuse somewhere. What is the test for a fried ECM? Wouldnt there be a CEL and an error code if that was the case? Seems Ive crossed jumper wires plenty of times without this happening!
Oh boy Im re reading your post here! You hooked up the batterys backwards and THEN tried to start it? Ive touched the terminals backwards but never tried to crank it like that! |
#9 | |
ekodrvr
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
Someone did that to my old car, a '71 ford. Although no electronics, it did fry the alternator. Sorry, closest I could help. I dunno about where you are, but we have some places here in the states that do free alternator testing. Might see if that is something that is available in your area.
Best of luck! |
lads, thanks for the suggestions so far. Im hoping it is the fusible link thats the problem ...my problem, I can't find it.
the manual for the 07 yaris seems to show it as being right beside the battery, i've looked and tried to follow the wires but cant locate it. i have a '00 model, apologies if this is a stupid question BUT could these fuses be in with one of the relays?? just i cant see any other fuses anywhere. cheers. |
#12 | |
ekodrvr
#13 | |
2000 Yaris Fusible Link.jpg If you pop the cover you'll see four link locations (three of which are populated): 2000 Yaris Fusible Link Block.jpg |
#14 |
I blew my fusible link by accident not too long ago... but its located under the red cover with the "+" on it over the positive terminal, it just snaps into place. Pull the red cover off and you'll see 2 60A fuses and if you have no electrical systems working sounds like both of those fuses blew.
Good news is they are like $12 from Toyota, call them and ask them to order you a fusible link, describe its location and its a super simple install * in the drawing above look under those fuses for the 60A fuses, those are like 20A (I think). The ones you are looking for are actually in the plastic and require that you replace the whole plastic connector piece. The 60A fuses are not relay-styled fuses
#15 | |
From the service manual, it appears that the 2000-2002 Yaris/Echo Fusible Link was a little bit different. The Main fusible link in the picture above is the equivalent to the built into the plastic ones in the newer Yaris. |
#16 | |
#17 |
![]() ![]() ![]() Drives: Blazing Blue Liftback Join Date: Oct 2008
I fried the Ecu in my wifes 4-Runner the same way. A very expensive lesson to learn.
#18 |
I havent read all the post but i can tell you, you have blown the main fuse. Which is why there is no power on the dash. Some cars can start with the main fuse gone but nothing electrical will work. Replace that fuse first and see what happens. After that to check if the computer has been damaged see if the check engine light turns on and then off when you first start that car that is a indicator that the computer has completed its self check. If it dosnt come on something is damaged.
| Tags |
| electrics, fuse blown, reverse polarisation, yaris |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
| What the Yaris community needs to take the Yaris to the next level | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 124 | 04-30-2009 02:03 PM |
