Old 06-25-2009, 05:41 PM   #1
AlanSRT4
Drives: SRT4
Exclamation Help needed guage lights out
The head lights still work but when they are on I get no dash lights at all the hvac nor speedo light up at all. And yes I played with the dimmer switch to make sure that it was in a postion where they should work and nothing. Any idea where and what to check. I checked the fuses under the hood and they were all good. Also I noticed that if the lights are on and the door is open with no keys in it does not give me that warning buzzer either now.
Thanks for any help you can give.
AlanSRT4 is offline   Reply With Quote
Old 06-25-2009, 05:48 PM   #2
silver_echo
ekodrvr
silver_echo's Avatar
there is a blown fuse under the dash... i don't remember off the top of my head which one, but i do know that it is under the dash...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 06-25-2009, 05:54 PM   #3
AlanSRT4
Drives: SRT4
that fuse area is behinde the little cubby hole that folds out right? and thank you for such fast response
Old 06-25-2009, 05:56 PM   #4
silver_echo
ekodrvr
yes that area, and no thanks needed... i just happened to be online... i had the same thing happened when i accidentally jumped the wrong wire for my aftermarket foglights... lost all inside lights at once...
Old 06-25-2009, 05:59 PM   #5
AlanSRT4
Drives: SRT4
cool will go and pull and check them and report back what I find.
Old 06-25-2009, 06:07 PM   #6
silver_echo
ekodrvr
now i have a slightly stupid question... were you doing anything under there when they went? if not, there might be an issue that would need to be looked into to make sure that it won't toast any more fuses... if that is what it ends up being...
Old 06-25-2009, 06:51 PM   #7
AlanSRT4
Drives: SRT4
just went over the 36,000 mile mark so no warrenty on something like this. and I do not feel like paying the bend you over prices they charge just to look at things. but I might go in tomorrow and see if they have any ideas the head guy seems pretty cool and feels bad for some problems we have had so he might have some ideas for us to check out. I guess I will try and find my circuit tester and check to make sure that the fuse is not bad and just looks ok, as well as check relays and such. Man just one I would like to have a summer hell a year where I work on a car only because I want to and not need to LOL
Old 06-25-2009, 06:57 PM   #8
silver_echo
ekodrvr
good luck with that... i am under the hood of at least one of my three vehicles at least once every couple months...
Old 06-25-2009, 07:17 PM   #9
AlanSRT4
Drives: SRT4
hopefully for fun and not from need.
finaly found the fuse panel that the smurfs they hired to hide it put it.
I keep looking at the main block behind the cubby hole had no idea you had to pull a panel off the btm of it then use voodoo to get in there.
6' 280lbs does not make for easier fuse pulling LOL
Old 06-25-2009, 07:21 PM   #10
silver_echo
ekodrvr
maintenance that i don't want to do, a leak on my jeep(one of many leaks) lots of other things... but no, for times that i want to be under the hood, it is like once a week...
Old 06-25-2009, 09:38 PM   #11
AlanSRT4
Drives: SRT4
and what the heck is up with the werid size fuse hardly anyplace has them let a lone know what they are.
Old 06-25-2009, 09:59 PM   #12
Actually they are easier to find than you'd think (at least around here). Before you replace the fuse make sure that you connected the dimmer wire from the Yaris's harness to the right place on your headunit's harness. That is most likely what popped the fuse in the first place.
And, at least they gave you a brake pedal as a headrest for changing fuses...
Old 06-29-2009, 11:22 AM   #13
AlanSRT4
Drives: SRT4
You were right the dimmer from the factory set up does not have anywhere that I can see to connect to the aftermarket one so I just capped off the wire and no more pop fuse.
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
LEDs to replace interior lights: Which ones? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 57 04-28-2010 01:44 PM
RS Lights .... reflector needed... YAR1S General Yaris / Vitz Discussion 8 03-13-2009 04:41 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
