Old 07-10-2009, 11:22 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
wheel weights vs stock????
would 36-37 lbs per tire and rim set up affect acceleration??
vs 33-34 lbs stock.
Old 07-10-2009, 11:47 PM   #2
Brian
Brian's Avatar
Most likely but probably won't notice it
Old 07-11-2009, 04:36 PM   #3
areithan1980
areithan1980's Avatar
Drives: 2007 Yaris Hatchback
how much does the tire weigh with air pressure on 45 mostly?
areithan1980 is offline   Reply With Quote
Old 07-11-2009, 09:24 PM   #4
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
I think you'd notice.
wheel/tire weights are really important, with all the options out there you really shouldn't go heavier unless you're going significantly wider for autox/track purposes.
although if you're going to a significantly larger wheel (17/18) and wider 7" 7.5" then adding weight is going to happen unless you get expensive wheels, so it's part of the territory.
you will notice an extra 4lbs per corner, if not in acceleration then in braking or cornering.
Russelt3hPirate is offline   Reply With Quote
stock wheel weight? whiteghetto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 02-06-2009 08:00 PM
Stock vs 123 Wheel HP (All-Motor) Dyno Graph richardholdener Performance Modifications 47 12-13-2008 09:13 PM
Stock Wheel Covers? barryware Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 11-04-2008 10:03 AM
stock wheel wushumasterku Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-23-2007 11:52 PM
