Old 07-12-2009, 08:13 PM   #1
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Dual antennas
So I think this is going to be temporary. The mounts are not as strong as I would like them to be. This is turning into such a pain.
Passenger side is an AM/FM 3' Firestik, and the driver side is a Wilson FGT 3' CB antenna.
Old 07-12-2009, 08:47 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
looks like Atom Ant , with bloody big feelers .
looks cool though
Old 07-12-2009, 11:45 PM   #3
Revsson
Diamond makes some nice mounts, though they are pricey.
They come in black as well.
http://www.rfparts.com/diamond/k400photos.html
Here is the main page for mounts.
http://www.rfparts.com/diamond/Produ...og/mounts.html
The K600 series looks interesting.
Just a thought.
How did you end up mounting the radios inside the car?
Old 07-13-2009, 12:12 AM   #4
auxmike
auxmike's Avatar
I had a wilson 1000 magnetic once. Those look kinda odd and a temptation for vandals or curious kids. Also, it screams "hey, I've got real expensive radio gear in my car".
Old 07-13-2009, 11:27 AM   #5
Sodium Duck
╚══════════RN
This is how I mounted my CB radio and stereo:
http://www.yarisworld.com/forums/showthread.php?t=17834
I think I'm going to end up buying one of those lip mounts. It's pretty much my only option. I did have some mirror mounts that I had screwed to the car, underneath the plastic triangle piece in front of the sideview mirrors. I figured it was just one sheet of metal I would go through, but there are about three layers, some are weak and give way as I was screwing in my self tapping metal screw -- it just wasn't good. I think I could easily get away with a lip mount on the fender... or get a 102" whip and a beefy Wilson roof mount. If you notice in my pictures, I removed the factory antenna completely. Had to drop the headliner and all that jazz.
Old 07-13-2009, 11:49 AM   #6
Sodium Duck
╚══════════RN
$76 dollars fors a K400?!?!
There has to be a cheaper option...
Old 07-13-2009, 12:50 PM   #7
Revsson
Yeah, like I said, they are pricey. Meant for ham radio I suppose,
but even hams have budgets.
Old 07-13-2009, 12:55 PM   #8
Sodium Duck
╚══════════RN
I'm a ham, and I could see paying for that mount if I had some big whopper expensive HF antenna... but for a 3' CB radio antenna, grrr. I gotta try and find something cheaper -- or attempt building something else.
Old 07-13-2009, 05:43 PM   #9
Sodium Duck
╚══════════RN
Bought a 102" whip this afternoon, pulled off the rear bumper, and test fit it on the actual metal bumper itself. It was a no go. Too much in the way, though it did just barely clear the hatch on opening and closing.
Looks like I'm back to the drawing board...
Old 07-14-2009, 01:17 AM   #10
Revsson
Maybe you could make something like this?
I'm trying to picture how that would look on a Yaris.
http://www.mfjenterprises.com/Produc...uctid=MFJ-2820
Old 07-14-2009, 12:08 PM   #11
Sodium Duck
╚══════════RN
The hatch would definitely whack the antenna. =/
*inaudible noises of frustration*
That's a cool idea though.
Old 07-16-2009, 12:47 AM   #12
Revsson
Just throwing out ideas to get your brain cells motivated.
Old 07-16-2009, 11:50 AM   #13
Sodium Duck
╚══════════RN
One thing similar to that that I was thinking about... Having someone weld a tab onto my tow hook and mounting a 102" whip off that.
Old 07-16-2009, 01:14 PM   #14
PatrickJohnson
Drives: 2008 Yaris LB
you could probably modify that license holder bracket to be attached to your mudflap (or mudflap area if you don't have them). Good placement and a good sturdy mount point.
PatrickJohnson is offline   Reply With Quote
Old 07-14-2009, 12:15 PM   #15
Sodium Duck
╚══════════RN
Maybe there's a way to mount it on the sideview mirror... I may take one apart later on. But then again, I'm not sure if the plastic would be strong enough to support it -- or that I could even get a good ground.
Old 07-17-2009, 02:48 PM   #16
llimonce
Drives: yaris sedan
i think i´ts better in the rear ..
llimonce is offline   Reply With Quote
Old 07-17-2009, 03:47 PM   #17
looking at post #1, couldn't you bend them back and attach the tips to the roof just above the doors?
Or is there some technical reason (reception and suchd) why that's a bad idea?
Old 07-18-2009, 09:16 AM   #18
Sodium Duck
╚══════════RN
My antenna's are very rigid and don't bend. Also, it would make them throw crazy SWR's on transmission.
I could mount them on the hatch area, but I'd need 2 of those ridiculously expensive K400 mounts that run $70 bucks each.
And I don't have the brass to drill holes in my roof, haha.
Shark Fin and Short Antennas JustAnotherAsian Cosmetic Modifications (Exterior/Interior) 137 04-21-2009 04:46 AM
dual antennas? Yanick In Car Entertainment + Electronics (audio / video / alarm) 1 11-10-2008 12:18 AM
dual exhast msfire671 DIY / Maintenance / Service 9 10-24-2008 08:24 PM
dual batteries or use a cap? punch In Car Entertainment + Electronics (audio / video / alarm) 14 07-17-2007 03:19 AM
Dual Exhaust elsteverino889 Performance Modifications 74 05-02-2007 09:08 PM
