Old 10-05-2006, 11:08 PM   #1
yaris-intuit
Aunty Yaris is In!
yaris-intuit's Avatar
Drives: Blazing Blue, 2 Dr Hatchback
Unhappy Sensitive Highbeams
Hi Guys,
Ever since I've got my car I thought the headlights seemed quite bright at times, but I had not push the switch forward to engage the high beams and the indicator was not on. I tested it tonight and all I need to do is push just ever so slightly forward and my high beams are engaged without it going into the proper "clicked" position. So, any motion like using the turn signal etc. can turn them on. I had the dealer install the cruise control; do they screwed something in the process?
yaris-intuit is offline   Reply With Quote
Old 10-05-2006, 11:29 PM   #2
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
mines seems to be the same way. just be careful.
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Old 10-06-2006, 12:02 AM   #3
yaris-intuit
Aunty Yaris is In!
Do u have the cruise control as well? I think this a problem, so I'm going to call the dealer. I've just broke the car in...1630 kms, so this should be under warranty.
Old 10-06-2006, 12:22 AM   #4
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
no i do not. however I do ntice right away when it happens, so it could be that yours may be a different problem. If it is a problem then they will cover it.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 10-06-2006, 10:11 AM   #5
tiksman
tiksman's Avatar
Drives: 07 Red Hatch
http://www.yarisworld.com/forums/showthread.php?t=878
Check here
tiksman is offline   Reply With Quote
Old 10-06-2006, 07:07 PM   #6
yaris-intuit
Aunty Yaris is In!
Thanks for the link! I just got back from the dealership and like in that thread they are going to replace the switch under warranty. The service assissant said it was ironic that 10 min. after I dropped off my car, he received an e-mail "Toyota Tech Tip" on that very issue for 2006/2007 Yaris.
I wonder how many complaints/repairs before an issue becomes a warranty recall and if this may turn into one for Toyota?
