Old 08-21-2009, 11:47 PM   #1
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Increasing backpressure?
I recently installed the nitto midpipe on my car along with the stock header and a tanabe madallion axleback. It feels like I dropped a lot of torque from 2-4k RPM and I usually don't rev higher than 4k Is there an easy mod I can do to temporarily inscrease some backpressure to regain some of that torque until I am boosted? Also for those of you who have the midpipe are you getting 100% success on getting rid of a CEL with that anti fouler deal the garm sells on his website?
Old 08-22-2009, 03:59 AM   #2
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
what is the diameter on your exhaust?
i believe the general rule of thumb is 2'' up to 120 hp, 2.25" up to 180hp, 2.5'' up to 250hp, 3'' up to 300-350ish, and 4.5'' for anything beyond
please dont quote me on this. its just general hearsay from my years around other forums.
Old 08-22-2009, 11:01 AM   #3
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
If you don't usually rev above 4k, then exhaust modifications are the wrong thing to do. Over the years, I have installed various exhaust modifications on vehicles I've owned and without exception, every one that reduced back pressure (on a stock engine) also reduced mid-range torque, sometimes by a substantial amount.
Most of these systems increased power in the upper RPM range, but for most street driving, that's pretty useless. If you have a big motor with lots of torque, it probably won't matter. But on a little engine like the Yaris has, a mid-range torque hit can be very noticeable.
Reddog99 is offline   Reply With Quote
Old 08-22-2009, 11:08 AM   #4
yes on the anti-fouler question.
Old 08-22-2009, 11:23 AM   #5
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
When I completed the 2.5" exhuast from the downpipe to the rear I really felt the difference in torque especially on the 3rd gear compared to the downpipe only. From this experience I understood well how much back pressure makes a big difference...
Parmas is offline   Reply With Quote
Old 08-22-2009, 04:36 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
it has less to do with back pressure, and more to do with velocity and/or laminar flow of the exhaust gasses. the higher the exhaust gas velocity, the more "smoothly" it flows through the exhaust pipe.
if you want more "back pressure" put in a smaller exhaust pipe.
Old 08-24-2009, 07:45 PM   #7
PHXDEMON
PHXDEMON's Avatar
I just don't want to hack up the nitto midpipe. I think I am just going to return it to stock
Old 08-23-2009, 05:01 PM   #8
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Also, did you reset the ECU? I just installed the DC header and had a similar issue. After an ECU reset I got most, if not all, of the mid-range power back.
Galavoxx is offline   Reply With Quote
Old 08-24-2009, 07:38 PM   #9
PHXDEMON
PHXDEMON's Avatar
Yes I did reset the ECU. Drove 20 miles and CEL came right back on.
Old 08-24-2009, 07:48 PM   #10
ChinoCharles
Drives: LB
Take it from me... on the subject of power, never make decisions based on "feel." Why don't you go dyno that thing and make sure you're not just feeling what you expected to happen rather than what actually is?
Old 08-24-2009, 07:56 PM   #11
PHXDEMON
PHXDEMON's Avatar
The power feels smoother throughout the whole RPM range it just lost a lot of "pep" at low RPMS It probably is making more power overall just less power where I typically use it on the street.
Old 08-24-2009, 08:28 PM   #12
06silveryaris
Drives: 2006 yaris
Not using a straight thru muffler will help the back pressure, like a dynomax turbo muffler or similar style.
06silveryaris is offline   Reply With Quote
Old 08-24-2009, 08:44 PM   #13
ChinoCharles
Drives: LB
I guess it is hard to justify spending money on a dyno visit to find out if you're gaining/losing 3 foot pounds at the wheels. Either way good luck with the decision.
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
