Audio Junky
Problems with Fiance's Subaru
So... clutch pedal was sticking a bit on the 00 legacy... did some research on the net... and didn't want the problem to get worse (to the point in which the pedal wouldn't return) when she was in the middle of her 8hr trip back home.... so thursday I picked up a slave cylinder for the clutch which was supposed to fix the problem....
Couldn't get the darn thing to bleed... spent 2 days fighting with it... then gave up and called a mobile mechanic.... guy fights for 2.5hrs and then says he thinks it's the master cylinder, not the slave that's bad. Makes sense cause the fluid won't drain into the slave the way it's supposed to when you bleed. Nobody open on sunday's has it in stock, tuesday is the soonest they can get one in.... and i'm supposed to leave town to drive 8hrs back home on wednesday after work.... oh yeah... the finace had to take my car since I phuqered hers. Slave = $45, master = $80-120 and the cost to rent a yaris is $42 a day I hate car problems. Sooo happy I have a yaris (Toyota)... can't wait till the GF can afford to get a new car and buy the 4dr HB or the Matrix. |
Audio Junky
$146 later its pretty much fixed... got a tiny bit of air somewhere in the system left to get out....it's pretty much good tho.
| new user with a couple of problems | grant_nelton | Great Lakes | 8 | 03-13-2009 10:18 PM |
| Problems? | Twistoffate0817 | General Yaris / Vitz Discussion | 35 | 12-24-2008 11:53 AM |
| some minor problems after installing my HID kit, any professionals? | ASHRAF | DIY / Maintenance / Service | 14 | 03-09-2007 10:54 AM |
| Timing chain, sprockets, & cam position sensor problems? | PetersRedYaris | DIY / Maintenance / Service | 8 | 01-04-2007 11:50 AM |
| Subaru Might Sell Rebadged Toyotas | 田中秀樹 | General Yaris / Vitz Discussion | 9 | 09-24-2006 10:10 PM |
