Old 09-01-2009, 12:58 AM   #1
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
TPMS light playing games.
so the other night on my way home the light decided to come on for the ride home. the next day it was on. finally two days later it turns off with out me doing anything with it.
anyone have this happen?
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 09-01-2009, 01:23 AM   #2
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
was it solid or blinking?
if it was solid (not blinking) most likely your air pressure was off.
If you have never checked the air in your tires I'd suggest to start doing it.
Old 09-01-2009, 11:02 AM   #3
If you want to find out what the issue is/was, you can get the TPWS to flash the light in a pattern which indicates what the trouble code is. Check out this post for instructions:
http://www.yarisworld.com/forums/sho...8&postcount=11
Old 09-02-2009, 08:41 AM   #4
bronsin
bronsin's Avatar
If you have a scan tool will the codes show up there? Thanks!
Old 09-02-2009, 08:51 AM   #5
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I believe there are separate electronic control units for the engine & transmission, the ABS system, the airbags, and now for the TPMS. They're accessed separately. The code reader only gets the info from the engine control unit.
Old 09-02-2009, 08:52 AM   #6
No (unless it supports Toyota specific enhanced diagnostics). Standard scantools, like the ScanGauge, only support some portion of the standard 229 engine / emissions PIDs.
Old 09-01-2009, 03:17 PM   #7
Cosmonaut
The Last Baron
Cosmonaut's Avatar
the light was solid. i checked it last night and the psi was at~23. so i bumped it up to around 31/28 and it feels a lot better now.
thanks scott that info is very helpful. its similar to reading diagnostics on my 87 mustang with the jumper method and counting blips. ill have to check it tonight to see what the code is.
thanks again.
| UR 19mm sway |
Old 09-02-2009, 12:01 AM   #8
Shroomster
Shroomster's Avatar
yeah if it was blinking it means lost communications..usually...it was still receiving signals from the tpms just not the correct psi.
Old 09-02-2009, 12:18 PM   #9
Shroomster
Shroomster's Avatar
^^^correct.
you need a toyota TIS scanner tool....techstream for short.
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
