![]() ![]() Drives: 2009 Toyota Yaris Sedan S Join Date: Aug 2009
Optima Yellow Top Battery Install
I have a Optima Yellow Top battery from my previous car and wanted to install it in my 2009 Toyota Yaris. Unfortunately, the battery terminals are on the opposite side and don't fit. I don't really want to buy a new one as they're expensive. Does anyone know if there is any way to extend the battery cables so they fit on the terminals or anything else I can do? Thanks for the help in advance.
I believe I have the Yellow Top D34/78 and from the Optima site... it says I need the D35. |
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
buy an orange top. or the similar red top, and put the yellow top in the back.
bam. ur good to go for a new stereo.
![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
Yes, you should be able to buy longer cables at a parts store, but what are you going to do with the "old" stock battery? They're probably good for 4-5 years, you know. I have a 2004 Ford Ranger and the original battery is still good...
Yeah, I'm connecting 2 amps for my sound system
Reluctantly Crouched...
Drives: 2008 Yaris HB M/T Join Date: Oct 2008
Well...have you tried putting the batter in facing backwards? Lengthening the cables would probably involve cutting and splicing, unless there are purpose-made cable extenders out there. If they exist, they'd be on ebay. :)
You can probably sell your Optima for a minimal loss and buy a new one that's correct for the application. Might only end up costing you $20-$30 bucks if your Optima is relatively new and in good nick. |
BTW -if you aren't adding significant stereo amps or a winch, there isn't much advantage to the optima. Might be worth your while to sell it and buy goodies from Garm...
Of course, no one on the forum is rocking a winch...YET! |
Yeah, most (if not all) Toyotas use a #35 battery. This is an industry designation and not from Toyota.
In other words, any manufactur's #35 battery will fit. Personally, I like Optima batteries and have one (red top) in my other car. Did you try turning the battery around? |
#8 | |
![]() ![]() ![]() Drives: 08 liftback 5spd Join Date: Oct 2008
And yeah, I tried putting it in backwards. I'm probably just giving it to my brother and do have to buy a new one :/
Tell him you'll sell him that $500 battery for a measley $150!! :)
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Can you install two batteries in a car? Maybe in the trunk?
| Tags |
| battery, cable, install, optima, terminal |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 02:40 PM |
| Lightweight battery install | Klink10 | DIY / Maintenance / Service | 11 | 02-28-2009 08:43 PM |
| Optima battery | yaris9876 | Performance Modifications | 0 | 09-09-2007 07:45 PM |
| will Optima battery fit in Yaris? | yaris9876 | Performance Modifications | 2 | 09-05-2007 10:52 PM |
