Reluctantly Crouched...
Drives: 2008 Yaris HB M/T Join Date: Oct 2008
drop/rub limits?
I knwo this has been discussed a bunch before, but I still cant' seem to get a definitive answer, if there is such a thing, so I'm going to go all "noob" on y'all.
Will a 215/40/17, mounted on a 17x7 +42mm, rub with the NF210's, in typical daily driving? I helped a friend install some used TRD's from a Scion (supposedly the same part# as the Yaris) on his yaris with similar size tires/rims, and his drop was almost 2", and they rubbed pretty easily on cornering and dips. OEM struts, cut bumpstops. I don't want this, but do want a mild (1") drop to close the wheel gap. I understand that some rubbing on very hard cornering and large dips is almost unavoidable on a dropped vehicle, but I really could only tolerate a minimal amount. Is this realistic, or am I going to need a different tire size to get what I want? |
1. the springs are all wrong, and dangerous
2. with a proper alignment you won't rub with that setup
Cool. Could you expand on the "wrong and dangerous" part? I'd like to pass this on to my buddy.
#4 | |
rear: the lower perches are completely different. the fact that you even got the springs to stay in at all is a mystery to me.
They fit the perches fine, so there must be more than one Scion spring set. Either that, or they were never Scion springs to begin with.
possibly a scion xd
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 02:57 PM |
| The limits of negotiating | 2+2 | New YARIS Purchase Forum | 12 | 08-05-2009 11:34 PM |
