Old 09-07-2009, 08:02 AM   #1
Is there any way to run 12" wheels?
I know people have run 13" Miata wheels (and some have found that some of the miata 13's don't clear the calipers). Is there any chance that 12" rims will fit, even if it requires a 1/2" spacer and longer studs?
The reason I ask is that the largest rim diameter for the swamp fox tires that I want to run on Crashy is 12". I found out that the Subaru Justy had 12" 4x100 rims, and they seem to be readily available at junk yards. Before I take the hour ride to the nearest place to me that has them I wanted to see what people thought about fitment.
Old 09-07-2009, 08:46 AM   #2
sex
sex's Avatar
Drives: 09 5DR
center bore is different: Justy is 56.1 compared to 54.1 for us
sex is offline   Reply With Quote
Old 09-07-2009, 09:17 AM   #3
Speedjunkiejp
Drives: 07 Yaris Sedan
hub centric rings can correct that.
To OP: Honestly i would drive and buy one to try it. They should charge you maybe $10-20 for one rim.
Speedjunkiejp is offline   Reply With Quote
Old 09-07-2009, 09:25 AM   #4
They are only $15 each, so that probably is my best bet.
Old 09-07-2009, 10:10 AM   #5
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Which means the wheel will fit just fine over the hub. All of the wheels in question are lug-centric, they don't require an exact fit on the hub bore.
Not sure you'll fit a 12" wheel over the Yaris front brakes, though.
Old 09-07-2009, 11:56 AM   #6
jonismyname
Drives: 08 liftback 5spd
rotor diameter is 10.03 inches. helpful? i dont know. but it's what i can lookup quickly at work on labor day...
jonismyname is offline   Reply With Quote
Old 09-07-2009, 12:01 PM   #7
jonismyname
HAHAHAHAHAHAHA
you should have included a link to what a swamp fox tire is.... hahahaha
http://www.powerpartsplus.com/pages/...snow-tire.aspx
Old 09-07-2009, 12:42 PM   #8
supmet
Drives: 2007 4 Door Yaris
Front brake delete FTW
Old 09-07-2009, 01:11 PM   #9
Small Brake Kit? (SBK?) hmmmm...
Old 09-07-2009, 02:30 PM   #10
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^haha
I cant wait to see where he goes with this whole thing
Old 09-08-2009, 02:57 PM   #11
I decided to try a quick fitment test this morning. I took one of the 12" wheels off of my tractor (with the swamp fox tires that I want to run on Crashy) and tried to see if it would fit over the caliper. Initially the dust shield was in the way, so I removed it. At that point I could slide the wheel most of the way on, but it is very tight. With the dust shield on, the inner diameter of the wheel needs to be just shy of 12". With it off, the inner diameter needs to be right about 11".
On Thursday I am going to take a run to the junk yard that has the Justy wheels, now that I know what measurements I need to check.
Old 09-15-2009, 06:39 PM   #12
arcticvitz
arcticvitz's Avatar
Drives: Base 09 White Yaris 3DR 5MT
Send a message via AIM to arcticvitz
Attachment 27957
Is your front end link bent or am I just seeing things?
Proud to purchase parts through
arcticvitz is offline   Reply With Quote
Old 09-15-2009, 09:25 PM   #13
It is bent. She has quite a few bent parts. I just replaced her bent axle and bent lower suspension arm on the other side.
Old 09-09-2009, 04:54 PM   #14
I checked out the 12" Justy wheels today and they are definitely a no-go. I found that the minimum diameter to clear the caliper is just shy of 11". The Justy wheels have an inside diameter of about 10 1/4". So, it looks like no 12" Swamp Fox tires for Crashy.
In doing some research on larger diameter ATV tires, I have found 15 tires. The smallest of which are 26x8x15, which will clear my lack of fenders, but I am not sure if they will clear for turning.
Old 09-09-2009, 05:56 PM   #15
jonismyname
sorry to hear that man. have you seriously considered the front brake delete? although the tire diameter would leave the front end sitting rather low wouldn't it?
Old 09-09-2009, 07:32 PM   #16
The tires that I was looking at (off my tractor) are 23x8x12 tires, so I would lose 1/2" if I was able to use them. They also come in 25x8x12, which would add 1/2".
Old 09-09-2009, 09:56 PM   #17
jonismyname
but it looks so small without the fender! hahaha
that was a bit of an optical illusion...
Old 09-09-2009, 06:24 PM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
is crashy an auto or manual?
you could always relocate the calipers/rotors to the differential a la H1 Hummer
Whats wrong with Rota's? mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 172 05-22-2009 11:13 AM
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
