![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
Thinking about flywheel & clutch...
I'm wondering what kinds of gains (if any) I can hope to achieve by changing the clutch and flywheel in my '09 LB. I'm not too sure what brands I should be looking at or what prices are reasonable for these parts, so I'm looking for some advice.
I'm not a racer by any means; I'm just looking to make my daily commute a little more enjoyable. For reference, I've already installed the following: NST crank, water pump, and alt. pulleys NST SSK (engine bay) TWM SSK (lower shifter lever) AFE intake Megan header & axle-back with custom mid-pipe |
Slowy getting there
There are no actual "gains'" in HP. What you will notice by installing these are quicker revs., a little harder clutch pedal, and the clutch will engage harder. As for where to get a flywheel and clutch: http://www.nonstoptuning.com/SPEC/pSpecClutch.html There are a few members on here that have actually installed these and will be able to give you a better review.
#3 | |
one would think the gains would be similar to that of
the NST pullies , Considering Spec flywheel is Approx 40% lighter than stock , check out the NST site they have the spec flywheel and clutch . |
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: NST CARS: S13 AE86 ANT10 AW11 Join Date: Dec 2006
And these are in stock and ready for immediate shipping. I would recommend the SPEC Stage 2+ clutch and lightweight flywheel for the Yaris. Good luck and have fun with your project! |
Apexing Egg!!
i would say very little... to me, it feels like it has a fairly good clutch, and the flywheel isnt that heavy. i would use that money to get an LSD.
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
![]() ![]() ![]() Drives: 2007 MX5 Join Date: Feb 2009
You're not gaining power but freeing up the power that is already there. I say do it.
unless you're making enough power for your stock clutch to slip, it's not time yet to replace or upgrade it. (unless you just want a stiffer feel). The flywheel will give you some responsiveness and "quickness" in your acceleration.
#10 | |
![]() ![]() ![]() ![]() ![]() Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
+1. i have a fidanza flywheel and TRD clutch. i prefer the stiffer clutch and like cali yaris said the flywheel adds a touch more responsiveness. it gives you the feeling that it has a little more pep when shifting but it's also more of a challenge to shift smoothly. tends to jerk the car around a little more. do i like it yeah but do i kinda wish i'd have put my money elsewhere yeah. |
Apexing Egg!!
i know alot of S2k guys use an upgraded pressure plate, stock disc, and lightened flyweel. I prefere that sort of set up, but i dont know if you get get a pressure plate without a flywheel.
On the yaris, with those mods, there is no reason to upgrade the clutch. The flywheel may be a nice mod on the other hand. Neither with make as big a difference as an LSD though.
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 07:14 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| Restarting car after popping the clutch... | PaidTimeOff | General Yaris / Vitz Discussion | 21 | 02-26-2009 01:40 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
| c one motorsport clutch line(pics) | badhabitz | Performance Modifications | 6 | 07-31-2006 10:08 AM |
