Old 09-17-2009, 12:55 PM   #1
chumpster
Drives: 2008 sedan
where is the 12V lighter socket fuse?
Hi,
I wonder if anyone can help. I have a 2008 4 door Yaris Sedan. Can anyone tell me where the fuse is for the 12V accessory/lighter socket. It's not specifically listed in the owner's book and none of the fuse circuits listen sound like they'd include it.
Thanks so much for any help!
chumpster is offline   Reply With Quote
Old 09-17-2009, 01:14 PM   #2
under the dash, under the panel by the hood release. It's listed in the manual (doing this from memory) in the 200's and either a 5 or 10 amp fuse. But it's there maybe number 7 or 10 on the list.
Old 09-17-2009, 01:33 PM   #3
chumpster
Drives: 2008 sedan
Thanks... I appreciate the advice. The dealership said they thought it was under the hood. Since there is no third option for a fuse box, that's both of them covered so far. I was hoping someone might at least know the name of the circuit it's on. I don't really want to take out each one and and test it!
I tried some guesses like the 'dome light' circuit fuse... no joy there unfortunately!
Does anyone know anything more specific?... thanks in advance.
Old 09-17-2009, 02:09 PM   #4
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
You can usually tell by looking at the fuse to see if it's blown. The little piece that runs across the two prongs in an 'S' shape will be destroyed.
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
Old 09-17-2009, 02:29 PM   #5
chumpster
Drives: 2008 sedan
I do appreciate the advice. I know what a blown fuse looks like and that they sometimes don't look that way, which is where a circuit tester comes in.
I appreciate the advice that it might be 7 or 10. It's an under the hood main box. 7 is no circuit with no fuse and 10 is the starting circuit, which functions normally. As does every other circuit I could guess it's on, like the interior lights etc.
This is the reason for my post to see if anyone might have some more detailed information as to where the 12V accessory circuit might be fused.
thanks.
Old 09-17-2009, 02:03 PM   #6
whats the problem?
Old 09-17-2009, 02:27 PM   #7
nick.dollimount
Yaris = <3
Okay, so I found the fusebox diagram for the inside fuse box under by the driver seat. You can see the fuse labeled CIG. It's a 15amp fuse. You should have some spare fuses under the hood in that fuse box. Also in there, is a little fuse puller; should look like a small pair of white tweezers. They definitely make it a lot easier
PS: Ignore the red circles in the diagram; stole it from another thread.
..:'; Nick ;':..
Old 09-17-2009, 02:31 PM   #8
chumpster
Drives: 2008 sedan
Wow... this is what I'm looking for... thank you so much!!! The manual makes no mention of anything under the driver's seat.... I'm off to the garage to investigate!
Old 09-17-2009, 02:38 PM   #9
chumpster
Drives: 2008 sedan
Well there's nothing under the driver seat other than the jack and nothing under the passenger seat.
This is a Year 2008 Model 1442 E Sedan.
So in summary... there's jack under the driver's seat
Old 09-17-2009, 02:43 PM   #10
chumpster
Drives: 2008 sedan
Maybe I mis-read your description... under, BY the driver's seat... mistakes happen ;-)
There is not much of an inside fuse box, just three major fuses, behind the panel. Most of the 5-20A fuses are under the hood. As I've mentioned the handbook is of no help in identifying which one might hide the accessory circuit. Plus everything is functioning normally other than this. I have a crappy car phone charger that sometimes pops fuses, which could be the culprit.
Old 09-17-2009, 02:41 PM   #11
nick.dollimount
Yaris = <3
Sorry, not the driver's seat... lol Under the steering wheel, if you pull down the plastic flap to give some light, or definitely use a flashlight, stick your head under and look up. There's a cover over the fuses that has them labeled as well. Not sure why I said driver's seat LOL
..:'; Nick ;':..
Old 09-17-2009, 02:42 PM   #12
nick.dollimount
Yaris = <3
Actually, it's under there and on the left side.
..:'; Nick ;':..
Old 09-17-2009, 02:46 PM   #13
chumpster
Drives: 2008 sedan
The manual talks about Type A and Type B... I'm sure they don't mean personalities!
I've found one fuse panel behind the little pull down door, that can be removed. Are saying there's another fuse panel more easily seen by Australians ;-)
Old 09-17-2009, 03:04 PM   #14
nick.dollimount
Yaris = <3
lol No, I think you found the right one
..:'; Nick ;':..
Old 09-17-2009, 03:30 PM   #15
chumpster
Drives: 2008 sedan
...and the winner is... 'The Yaris Forum' and it's 'hive mind'
So much for the owner's manual and the dealership on the phone.
It really is a difficult little fuse box to find. The nice diagrams in the owner's manual show where the big box is behind the panel door... but seems to stop there and not clearly indicate where the important little box is. I'm glad I wasn't stuck on the side of the road! I think even James Bond, would have been on his Sat Phone calling Q... er Q... er,.. do you know where the fuse box is mate?
thanks again...
Old 01-13-2017, 09:59 PM   #16
ivee1313
Drives: 2008 Yaris
Thumbs up and again THANK YOU ALL!
thanks again...
Still helping people in 2017. Just the info I needed! Thank you so much!
ivee1313 is offline   Reply With Quote
Old 09-17-2009, 02:48 PM   #17
nick.dollimount
Yaris = <3
http://www.yarisworld.com/forums/att...9&d=1250041800
If you can see this thing ^, Look underneath it. It's really hard to see under there or get your head under to see anything. You'll see a strip of paper on a cover. It's long. It has the fuses indicated on it. Pop that cover off and they're all underneath it.
..:'; Nick ;':..
Old 09-17-2009, 03:32 PM   #18
nick.dollimount
Yaris = <3
hah No problem =)
..:'; Nick ;':..
DIY Powered USB Ports BailOut DIY / Maintenance / Service 27 02-22-2017 10:17 AM
Cigarette Lighter Fuse stellar DIY / Maintenance / Service 10 01-30-2010 03:08 PM
2009 empty, usable fuse location? schleppy In Car Entertainment + Electronics (audio / video / alarm) 3 04-23-2009 12:07 PM
Ipod Lighter Socket Mount... anyone? kapo In Car Entertainment + Electronics (audio / video / alarm) 1 08-14-2007 01:31 PM
How to remove the lighter socket? solana_sc DIY / Maintenance / Service 7 12-26-2006 05:47 PM
