Old 09-25-2009, 10:31 AM   #1
conurebuddy
Drives: 5 dr Yaris LB
Back wiper
When I turn on the rear wiper in my hatchback, it makes this god awful noise like its not moving smoothly across the window. It just sounds like rubber skidding across glass. Anyone know how to stop this so I can leave the wiper on when it rains?
conurebuddy is offline   Reply With Quote
Old 09-25-2009, 10:57 AM   #2
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
soak the blade in vinegar it will losen it up
or it will break in over time
http://www.4055design.com
Old 09-25-2009, 01:04 PM   #3
Liltoaster
Drives: 05 Echo H/B
I soaked my other car's wiper in vinegar and it works like a charm :)
Liltoaster is offline   Reply With Quote
Old 09-25-2009, 01:23 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
you guys are serious? soak in vinegar?
Anyhow.. when i had my hatchback, my windows had always been treated with RainX, never had probs..
Old 09-25-2009, 01:57 PM   #5
supmet
Drives: 2007 4 Door Yaris
Ya, it didn't get my hard water spots, and it didn't really help with a sunburn. I think people are just mean spirited and want you to smell bad on top of your initial problem.
But I guess its supposedly true:
http://www.thriftyfun.com/tf48399082.tip.html
Old 09-25-2009, 02:17 PM   #6
Snappy
Drives: 2 Yaris Hatchbacks
You could try cleaning the rubber part of the blade with a paper towel soaked with windshield washer fluid. The rubber oxidises a bit with time, and this can remove some of the oxidation. And if the glass has water spots, you could try using a clay bar to remove them from the glass. But I personally just leave the rear wiper off, and just turn it on for a single wipe or 2 every now and then manually.
Snappy is offline   Reply With Quote
Old 09-25-2009, 04:05 PM   #7
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
mine only makes a little noise until i run some of the washer fulid and then it gets real smooth sounding...i just assume there is debris on the rear window that causes friction but, once the fluid gets in there it's all gravy...
Old 09-26-2009, 01:42 AM   #8
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
After I wax my car I use the wipe off cloth to wipe my windows. It leaves a wax film and the wipers wipe better.
Old 09-26-2009, 10:56 AM   #9
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Thought you weren't supposed to do that, makes the wipers worse in the long run.
Old 09-26-2009, 12:33 PM   #10
yaris-me
Learn to Relax
I replaced my wipers after three years. I don't think the wax hurt the rubber. I think the sun does more damage. I still have my back wiper. It works just fine.
Old 09-26-2009, 02:12 AM   #11
st0rmfreak
constantly changing
st0rmfreak's Avatar
Drives: 2008 Toyota Yaris lb
when that happened to mine i just simply turned the wiper around. its worked fine ever since.
_______________________________________________
st0rmfreak is offline   Reply With Quote
Old 09-26-2009, 05:50 PM   #12
RedRide
RedRide's Avatar
I have the same exact problem with my rear wiper.
The rear wiper blade rubber really does seem stiffer then the front.
I wiil try the vinigar trick before replacing the rubber with some stock I already have on hand, that is used but, is stiil servicable.
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
Looking for GTA HB to test Axle Back System RaptorRacing Canada 8 11-28-2008 11:14 PM
So we just came back from TRD Thailand... eTiMaGo Performance Modifications 28 03-21-2007 05:52 PM
Rear wiper function, is this normal? Yaris Dick General Yaris / Vitz Discussion 7 11-08-2006 09:46 AM
