![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Moving the Ignition To The Left?
OK, this is for you big brains out there...
A lady I know has a Yaris sedan and due to physical limitations she has a hard time starting the car with the current location of the ignition. It would be considerably easier if the ignition could be moved to the left side of the steering wheel instead of the right, but is this even possible? I don't know if she would be willing to do any major modifications to her Yaris but if this was possible she may just consider it. I just don't know if it is even feasible to move the ignition switch from one side of the steering wheel to the other. Does anyone know? Cheers! M2 |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
A new ignition switch can be placed somewhere on the left side, but the steering wheel lock is a different matter.
Flip the whole steering assembly upside down
I suppose you could remove the wheel lock, I have never tried though. It should be easy enough to get an aftermarket ignition cylinder to embed in the dash on the left
The Last Baron
Drives: 09 Polar White HB Join Date: Jun 2009
would a push-start button work?
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires! | UR 19mm sway | |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| FS: Motec M4 Standalone ECU w/ Ignition Expander | Biggie™ | Items for Sale by private party | 6 | 10-20-2009 02:36 PM |
| Will local bay area members please stand up! | YarisSedan | California | 264 | 07-28-2009 11:53 PM |
| 2007 Yaris Sedan S Ignition won't turn | koharegistrar1 | DIY / Maintenance / Service | 7 | 12-24-2008 08:34 AM |
| Ignition Issues | kike | DIY / Maintenance / Service | 5 | 10-31-2008 01:43 AM |
