Old 10-03-2009, 06:59 AM   #1
mr_eraserhead
Drives: Extreme Black Vios
Unhappy Sedan Ducktail installation problem
Fellow yarisworld members,
I'm from the Philippines i own a Extreme black Vios/Yaris Sedan and i need help in my newly installed ducktail. Its fiberglass molded form the XX limited edition grade vios/yaris ducktail. After purchasing the ducktail from a local store, i had it body colored in a auto paint shop. After installing the ducktail, i noticed that the fit of the ducktail isn't perfect! There is a gap in both ends of the ducktail! What can i do to solve this problem! It really bothers me everytime i look at it. I want it look perfect
As you can see from this angle it looks fine
But when we look at the sides,
The 3M double adhesive is visible
I need your help fellow yarisworld members!
what can i do to repair this? Someone told me about a sealant that can cover this up. I need your help. Thanks!
mr_eraserhead is offline   Reply With Quote
Old 10-04-2009, 01:01 AM   #2
JayTee09
4dr=FTW
JayTee09's Avatar
Drives: Yaris Sedan
Go to autozone and get some 3M emblem glue a little of that stuff goes a long way
JayTee09 is offline   Reply With Quote
Old 10-04-2009, 01:05 AM   #3
LEGATO``
LEGATO``'s Avatar
...they don't have autozone in the philippines, i believe haha
but what he said may be right though, just get some glue from a auto store
Project LEGATO
Old 10-04-2009, 01:50 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Please take a picture of the underside of the wing.
I assume it's a knock-off of the real wing?
Old 10-04-2009, 02:43 AM   #5
Hey. I'm assuming everything is held on by double-sided tape. So, get some masking tape, put it on the sides and mark both edges with a marker. This will be used as a guide point in the next few steps. Now, remove the spoiler and get rid of that extra thick tape. Go to an auto store or a hardware store, and buy some extra strength double-sided tape that's relatively thin. Next, slap that onto the spoiler and reattach the spoiler using those guide markings you made earlier.
Old 10-04-2009, 07:32 AM   #6
mr_eraserhead
the problem here is that the wing's fit isn't perfect that's why that gap is visible. i don't want to spend again on buying a new wing just to have that "perfect fit". what can i do?
Old 10-04-2009, 10:15 AM   #7
frownonfun
frownonfun's Avatar
i think what kaotic is saying is some thinner double sided tape might help close that gap a little.
I crush you like tiny clown car, because you are clown, yes?
Old 10-04-2009, 12:02 PM   #8
mr_eraserhead
yes i get what kaotic is trying to say. But my dilemma is that the wing itself is the one causing that gap. not the tape. on the left side of the wing, a part of the tape does'nt even get to stick on the car's body because the fit of the wing isn't flat perfect. what do i do? Do i need bend the wing somehow?
Old 10-04-2009, 07:42 AM   #9
mr_eraserhead
by the way this is the original ducktail. mine's fiberglass (xx limited edition vios from the philippines)
Old 10-04-2009, 12:42 PM   #10
frownonfun
frownonfun's Avatar
oh... i c. you could try sanding it down on the bottom side so it sits more flush. perhaps.
Old 10-04-2009, 01:29 PM   #11
mr_eraserhead
ok ill try that. thanks!
Old 10-05-2009, 12:39 AM   #12
JayTee09
4dr=FTW
JayTee09's Avatar
Drives: Yaris Sedan
^^ sorry wasnt paying attention to where the OP lived lol as far as it not fitting if it were abs you could try heating it but since its FC I would go with what Frownonfun said try sanding it
ducktail, installation, problem, sedan, trunk
Problem with GTspec strut bar installation Yawesh Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 03-20-2009 03:55 AM
Sedan Fog lights Installation JumpmanYaris DIY / Maintenance / Service 2 03-17-2009 11:28 PM
