Old 10-03-2009, 08:55 AM   #1
bribri
Drives: white stock yris
oil overfill for track
I heard that it's good practice to slightly over fill the engine oil so the oil level won't be too low in corners due to centrifugal forces. Is this correct? Can the engine have a oil pressure drop because of this? How much extra oil might help?
bribri is offline   Reply With Quote
Old 10-03-2009, 02:00 PM   #2
soloecho2
soloecho2's Avatar
Drives: 2004 Echo HB
I would say NO. On the tracks we are running the corners are too short to slosh the oil away from the pick up. It could happen in looooong sweeping corners. I don't know the set up of our oilpan but excessive oil can cause a decease in HP because the crank has to push the oil out of the way.
soloecho2 is offline   Reply With Quote
Old 10-03-2009, 02:38 PM   #3
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Based on our oilpan orientation, I'd say that oil starvation is unlikely. Its not at all liek the V8 RWD oilpans, and our engine tolerances are so much tighter that I'd be very cautious about doing non-spec thinks inside out motors.
Old 10-03-2009, 07:11 PM   #4
bribri
Thanks.
Old 10-03-2009, 11:50 PM   #5
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
ive always put in 4 qts. manual says 3.8 but 4 wont hurt.
Old 10-04-2009, 08:21 PM   #6
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
thats been my routine. no problems
Old 10-04-2009, 11:52 AM   #7
Lafiro
Drives: 06 Yaris Sedan
Whats with the fighting? If the manual stated 3.8quarts. Then that should be the sweet spot. I myself put in 3.5, only because someone told me slightly below the full marker is better then filing it to the max or more.
I also asked a few people about this, and they also told me to NEVER fill up more oil then needed in the motor, and especially not in the transmission either. It will either cause HP loss, or damage.
Thats what I was told myself, as for the proof, I don't have any but to listen to people in the business itself.
So everyone is right and wrong in every opinion. But honestly, I will have to also say, don't overfill, leave that .2 to .4 quarts for the next oil change, you will be saving yourself a little money in the LONG run. And who knows about the engine.
Old 10-04-2009, 06:15 PM   #8
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Rather than bickering about it, has anyone even bothered to let their engine sit for an hour, fill it up to exactly the full mark on the dip stick, then start the engine and let it idle for a minute of two and then shut it off and immediately check the oil level to see how much oil is actually still contained in the galleries of the motor and on the inside of the block and hasn't yet managed to return to the sump?
After a hard fang in my old rally car, you could pull the dipstick and have no oil what so ever showing on it, but give it 5 minutes, and it would be back up to the full mark.
rob323 is offline   Reply With Quote
Old 10-04-2009, 07:17 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
supmet, talk to 2zzge owners about the virtues of under-filling your oil pan at the track, and get back to us.
Old 10-04-2009, 09:51 PM   #10
mikenacarato
SIPNDEW
Drives: 15 STI
well aparently alex, were wrong...this is why i dont come to this forum much anymore because everything anyone does is wrong and someone else is right. way to let YW slide down the hill people.
Old 10-04-2009, 09:54 PM   #11
rob323
I would have thought there were more people agreeing with you (me included) than against you.
Old 10-04-2009, 09:59 PM   #12
supmet
Drives: 2007 4 Door Yaris
There is a difference between overfilling for the track, and saying it won't do anything bad at all. Doing it at the track is the lesser of two evils. Doing it all the time for the one time in your life you might hit a turn for hard and long enough to starve your engine, just doesn't make any sense.
Please explain why, if I'm wrong, the manual doesn't say put 3.7 to 4.0 liters. Explain why there are thousands of google hits talking about the bad effects of overfilling oil, and the damage it does.
Old 10-05-2009, 12:26 PM   #13
supmet
read the fking title of the thread
... read the posts. Shouldn't you be throwing a fit and telling everyone you're gonna quit YW again by now?
ive been running 1 whole gallon of oil for the last 20k miles... .
Old 10-04-2009, 10:01 PM   #14
mikenacarato
SIPNDEW
Drives: 15 STI
well some people on here just need to learn some stuff, thats all.
mine is always at 4 qts wether im at the track or on the street. hasnt hurt anything now and from my past experiences, it wont hurt anything later.
by the way...liters and quarts are not the same thing supmet... 4liters = 4.2 qts, whereas im not putting in 4 liters...im putting in 4qts. i still have yet to find a place that states .2 qts of fluid will damage anythin0g.
another thing, dont leave that .2 or .4 qts for later...because by the time that later comes..the oil has broken down and becomes useless. same goes with open bottles of brake fluid, trans fluid, and really any oil based lubricant non aresol based.
Old 10-04-2009, 10:43 PM   #15
bribri
sorry I asked
End of thread
Old 10-04-2009, 10:54 PM   #16
soloecho2
soloecho2's Avatar
That will learn ya. Ha Ha Ha. See you next Monday
Old 10-04-2009, 10:55 PM   #17
mikenacarato
SIPNDEW
Drives: 15 STI
why should you be sorry? you asked a legitamate question and the people who dont even track their cars piped in to give no knowledge whatsoever.
Old 10-05-2009, 12:37 AM   #18
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
lol, he is a mechanic now, dude 4 qt wont do jack to ur car its ok its going to be OK
Originally Posted by sw07gt
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
leaky seal on engine? oil overfill? jeff69dini DIY / Maintenance / Service 23 06-07-2010 12:52 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
