Old 10-16-2009, 12:01 PM   #1
chew246214
Drives: 2009 yaris sedan base
fog lights 2009?
OK not too sure if I messed up or not.... Just picked up a 2009 sedan base..... wanted fog lights and found an aftermarket kit that I couldn't refuse on the price with the complete wiring harness..... It's part # wj30-0074-12 made by winjet... yellow oem style for 4 door..... Recieved it quickly and prompt but my concern is the box says "2006-07" Will these fit???? before I take the car apart and find out otherwise I figured I would ask here..
any help would be appreciated.......
chew246214 is offline   Reply With Quote
Old 10-16-2009, 04:06 PM   #2
AzNguy
Drives: Toyota Yaris Sedan 2009
nah, i'm sure it's the same. my '09 sedan looks same as my friend's '07 sedan in the foglight perspective. ;)
AzNguy is offline   Reply With Quote
Old 10-16-2009, 04:30 PM   #3
that's good, the liftback's shroud changed but the rest of the kit is the same.
The switch won't fit, and you don't get the OEM wiring kit and instructions that comes with ours. Otherwise, about the same.
Old 10-16-2009, 06:41 PM   #4
chew246214
I appreciate the help here.... The kit is complete with wiring, switch, bezels, and lights.. all the wires have plugs on them except the ground wire... Not too sure how plug and play it really is... The instructions were just a waste of time that came with them... But new in the box for $30 shipped I figured I can splice some wires.. I've been known to do that once in a while.. When it dries up a bit I'll start into the project... I have a bunch other outside stuff to do also.....
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
duda con 2009 yaris sedan fog lights dassoe09 Caribbean 17 06-14-2009 01:56 PM
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
Fog lights on 2009 LB Chupacabra DIY / Maintenance / Service 2 11-17-2008 11:26 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
