Old 10-24-2009, 01:35 PM   #1
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
NEED IMMEDIATE HELP: Locked Up With P/S Light
heres the short, i swapped my alt for a ho alt. It fit fine etc but i had to extend the black connector that goes in to the brown port on the alt.
So i did and i popped it in and re-tightened the belt and started the car up.
the car turns on fine and the dash lights up but the P/S light comes on and the car wont come out of park, its locked up.
also the fan wont come on as well as the a/c
PG TLD22 8V Line Driver
Old 10-24-2009, 02:07 PM   #2
drew113087
newbie to this site again
Drives: 2007 yaris Sedan
lol I ended up w/ the same problem when going on a accidental fuse blowing rampage about 6 months ago :D. Anyways here is a temporary fix: look at your gear selector assembly between the two front seats. There is a a black tab above the "P" and to the left of the gear selector stick. pry off this tab with either a butter knife, or whatever you can find that wont stratch the cosmetics. now you shold see a button that will allow you to shift gears.(ps don't be like me and improperly secure youre remote turn-on wire, because it will lead to multiple blown fuses :P)
drew113087 is offline   Reply With Quote
Old 10-24-2009, 03:24 PM   #3
auxmike
auxmike's Avatar
Wow, that's awful.
I'm keeping my car all OEM excluding the TRD axelback. Seems like these cars are REAL sensitive to the slightest changes...
Old 10-25-2009, 01:18 AM   #4
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
Originally Posted by auxmike View Post
Wow, that's awful.
All cars are sensitive to improper installations.
RUFFSTUFF is offline   Reply With Quote
Old 10-24-2009, 11:21 PM   #5
Did you check for blown fuses as mentioned above?
If it's not a fuse, does you HO alt provide the signal feed on the pink wire that goes to the ECM and the AC amplifier?
Old 10-25-2009, 02:13 AM   #6
YarisSedan
Drives: 08 Yaris Sedan
Possible problem with the altenator since it is in all actuality a rebuilt. Someone custom rebuilt it for more power. Easy way to check is throw your old one back in and if everything magically works then you know thats the problem. If nothing works still then you blew a fuse. Did you DISCONECT the battery before you removed and installed the altenator? If not you probally blew an important fuse thats causing all your problems.
Otherwise you may have possibly damaged the ecm
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
My Yaris Fog Light ezlove0710 DIY / Maintenance / Service 7 08-07-2009 06:15 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
