Old 10-28-2009, 06:37 PM   #1
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
1zz Throttle Body - what needs to be done to it
I ordered myself a 1zz throttle body from a Corolla with a 1.8 liter engine.
I've got it coming with all the sensors and stuff, I just need to know what I need to change out on it and swap from my stock throttle body to make it work in the yaris.
I know stretching the tubing onto the TB is difficult, I just don't know the other details that need to be changed on it.
Your input is very appreciated.
(I've searched and read several threads, but couldn't find the answer I'm looking for, if it is already on the forums, please just point me in the right direction).
Edit: Want to do the chip swap from this thread: http://www.yarisworld.com/forums/showthread.php?t=14672
but the DIY is gone, so if someone has a link to info on the chip swap, or can describe it for me, it would be much appreciated.
Edit: The more and more I read, the more I am understanding, but if anyone has any other kind of info they want to add, please feel free, or the mods can remove this thread since there are several for this TB already.
Thanks!
Old 10-31-2009, 09:30 AM   #2
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
i am gonna get one from a matrix, lemme know how it goes for you. I hear the matrix one doesn't throw a light as much.
chongopants is offline   Reply With Quote
Old 11-02-2009, 08:41 AM   #3
hatchbackkid82
Drives: .
Don't even do it!!!! Save your self the time and money. This mod has been soooo unreliable there are only a few members on here that have gotten it to work sucessfully
Old 11-12-2009, 06:21 PM   #4
kac
kac's Avatar
Update: Installed 1ZZ throttle body today (from Garm, THANKS! great price, that guy is awesome)
Works Great! No check engine lights At All. Idle was high for a couple minutes when first started and has not been high at all since even at start up.
LOVING IT.. Only problem is I should have done it sooner! Great Mod!
(Also put on some Micro Image decals which look great, Thanks Garm!)
Old 11-13-2009, 12:17 PM   #5
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
So, do you feel any difference now? More power, better acceleration? Review please
fmicle is offline   Reply With Quote
Old 11-18-2009, 10:50 AM   #6
2bad4u
Drives: 06 Toyota Vitz RS
TB Chip swap
[QUOTE=kac;414134]Update: Installed 1ZZ throttle body today (from Garm, THANKS! great price, that guy is awesome)
Did you do the chip swap or installed the 1ZZ tb with the original corolla chip??
The reason I am asking I also got a 1ZZ tb from Garm but have not installed.
Last edited by 2bad4u; 11-18-2009 at 10:52 AM. Reason: just read all post you did the swap thanks
2bad4u is offline   Reply With Quote
Old 11-20-2018, 02:32 PM   #7
DarkShadowFox
part #
Old 11-20-2018, 06:13 PM   #8
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
Originally Posted by DarkShadowFox View Post
part #
22030-0D030
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Freestylin is offline   Reply With Quote
Old 11-13-2009, 08:09 AM   #9
hatchbackkid82
Drives: .
see now you got me wondering, if i should just give this one more shot. That was my intial plan since the first one didn't work. i figured i would just try it again in a few months.
Old 11-13-2009, 09:44 AM   #10
^ I keep telling you guys, it works if it's done carefully and properly.
I do not believe that some TB's work and some don't. It's a TB with a servo motor, all the juicy stuff gets swapped out.
Old 11-13-2009, 10:49 PM   #11
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Yeah I am going to have to disagree with that statement.
Old 11-13-2009, 12:06 PM   #12
redglare45
redglare45's Avatar
Drives: 07 Sedan - 5 Speed Manual
Hmm, makes me wonder about trying this mod too
redglare45 is offline   Reply With Quote
Old 11-13-2009, 02:04 PM   #13
kac
kac's Avatar
similar to when i modified the air intake box to make it more like a cold air intake of sorts... I notice better acceleration in the higher RPM range, and a little better throttle response.
Old 11-14-2009, 02:31 AM   #14
kac
kac's Avatar
maybe carefully and properly wasn't done EXACTLY to the letter in that circumstance which would just add more support to what Garm said.
Old 11-14-2009, 06:46 AM   #15
jmew0ng
Drives: Scion FRS
For the TB purchased from Garm, is the chip swapped for that one?
jmew0ng is offline   Reply With Quote
Old 11-14-2009, 09:41 AM   #16
kac
kac's Avatar
Yes i swapped the chip.
Old 11-14-2009, 12:04 PM   #17
chongopants
Well all we need is a comprehensive how-to on buying...modifying...and installing... the TB until someone sells it specifically for that reason (which is an incredible idea btw)... So I can say I am very much intersted in that if anyone decides to do it... Just coming from vehicles that didn't have a TB that is near the same...
Old 11-16-2009, 06:14 PM   #18
echosqwat
echosqwat's Avatar
Drives: Porsche Boxster
If you are not doing head work (bigger valves, porting, different cam) and improving intake manifold too ....how does this improve anything?
Sounds like a waste of time. Or is it mental HP youre gaining?
echosqwat is offline   Reply With Quote
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
FS: 1ZZ throttle body and Fujita intake mrbond Items for Sale by private party 25 09-08-2009 10:21 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
Intake for the 1ZZ throttle body? fuji Performance Modifications 9 06-14-2009 12:02 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
